Author Topic: Temp probe with SHT35  (Read 7007 times)
Offline Mandrake
« on: April 23, 2020, 10:22:26 AM »
Exciting news...
Ecowitt have a temperature sensor in dev/test with a SHT35 on board
I am just so impressed with the company and team, they so listen to their customers!
G1ZFO
Ecowitt GW2000 (Test)
Ecowitt WS90 Wittboy - Test
Ecowitt WH41 PM2.5 AQM Sensor
Ecowitt WN35 Leaf Moisture
Offline JB007JB
Re: Temp probe with SHT35
« Reply #1 on: April 24, 2020, 04:19:50 AM »
What are the differences or advantages to the currently available sensors?
« Reply #2 on: April 25, 2020, 12:17:32 AM »
I hope that they lower the humidity range that is currently limited to minimum 10% RH.
This needs to go into the outdoor WH32 so that we can upgrade current stations. Maybe it should be called the WH35 (I don't think that exists).
Offline Mandrake
« Reply #3 on: April 25, 2020, 06:50:06 PM »
Lucy, advises that this is close to being available, so we will soon see.
I imagine the benefits will be the sensor precision
G1ZFO
Offline mauro63
« Reply #4 on: April 26, 2020, 06:37:52 AM »
I can confirm, the idea was started from my personal push to ecowitt, supported by our italian community, due to would like to have a better sensor, a lower probe dimension and to obtain the best performances using this sensor in high quality solar radiation shields, like Barani Meteoshield Pro that require a low dimension probe to obtain the best internal airflow
the first prototype, tested by ourselves, was made by an our top user, Raffaello, sometimes present in this forum
if you want I can post an image of probably definitive sensor
Mauro
« Last Edit: April 26, 2020, 06:39:28 AM by mauro63 »
Offline mauro63
« Reply #5 on: April 27, 2020, 06:30:15 AM »
A news about the new Ecowitt sensor with sht35 external probe
the price will be 49,99 USD plus shipping
Mauro
« Reply #6 on: April 27, 2020, 06:58:56 AM »
Okay, but does it have the 10% humidity limit removed?
Offline ivano
    • http://www.supermeteo.com/stazione/ortelle/
« Reply #7 on: April 27, 2020, 08:40:15 AM »
il prezzo è accettabile , la qualità costa , ci sono sensori che costano lo stesso e non sono nemmeno degni di essere presi in considerazione  ;)
1)3 gw1000 +1 GW2000
2)hp2551
3)ws80
4)ws68
5)2 wh32 EP
6)5 wh31 EP
7)2 meteoschield pro 3° gen
8)1 Fars meteoshield pro 3° gen
9) davis 7714 Black
10)wh40
11)schermo solare RAD-14 Metspec
12)schermo solare RAD-02 Metspec
13)Meteorain 200 compact (Barani)
14)davis ventilato h24
15) Davis vp2 pro ventilata
16) GW1001 ecowitt
17) Wittboy ecowitt
18)schermo solare  Comet system da Cometeo
template http://ortellemeteo.altervista.org/pwsd/
webcam :https://rtsp.me/embed/tRhazi3z/
Offline gand
    • Lynghuzed
« Reply #8 on: April 27, 2020, 08:45:15 AM »
Hi Mauro
Please post some images.
Shipping to Europe will be around $7 and Express $18
Gert
Offline mauro63
« Reply #9 on: April 27, 2020, 08:56:03 AM »
Hi Mauro
Gert
of course  ;)
a probable end product image
probe inside Meteoshield Pro bottom clamp
Mauro
Offline mauro63
« Reply #10 on: April 28, 2020, 09:21:48 AM »
I can officially confirm that the new Wh31/32 sensor with external sht35 probe will not have the humidity lower limit at 10%
Mauro
Offline mauro63
« Reply #11 on: April 29, 2020, 05:38:55 AM »
I can give the order code for Wh sensors with sht-35 external probe
WH31-EP
WH32-EP
Mauro
Offline mauro63
« Reply #12 on: May 04, 2020, 02:49:25 AM »
Yesterday a good day to test the performance of the sht35 external probe inside meteoshield pro vs the wh31 standard sensor inside another meteodhield pro
Mauro
Offline mauro63
« Reply #13 on: May 07, 2020, 05:35:30 AM »
a little presentation about new WH31/32 EP series with external Sensirion SHT35 probe
Mauro
https://drive.google.com/file/d/1Y48DSfO0Q0U7gE1OFjvf0FhLTe1ldl-8/view
Offline GHammer
    • Woodmar Weather
« Reply #14 on: May 08, 2020, 03:32:58 PM »
What is the difference between the WH31-EP and WH32-EP?
Wireless Vantage Pro2 Plus with 24hr FARS, WLL
« Reply #15 on: May 08, 2020, 03:43:27 PM »
Same difference as WH31 and WH32.
The WH31 is the optional sensor model where you can select up to 8 channels, allowing you to have 8 extra optional sensors.
The WH32 is the given main and only outdoor sensor for the station and also serves as an outdoor override for the WH65 or WS80.
Offline KD7GFL
« Reply #16 on: May 18, 2020, 06:49:29 PM »
Any update on when the new sensors will be available?
I want to get a new Ecowitt station, but I want to wait until I can get it with the new sensors.
CWOP: KD7GFL (AV640)
WU: KMOAUXVA6
Ambient Weather: KD7GFL
Equipment: GW1000, WS-68, WH40 (w/WH65 Funnel for improved accuracy), WH32-EP (Davis 7714), WH-31 X 2, WH-32, WH-57, HP2551-C, and an Ambient WeatherBridge.
Offline mauro63
« Reply #17 on: May 19, 2020, 04:47:41 PM »
the new wh sensors with external probe sht35 are not yet visible on the site but can already be ordered
presentation on the site, manuals, etc will be available shortly
Mauro
Offline GHammer
    • Woodmar Weather
« Reply #18 on: May 19, 2020, 06:35:46 PM »
Mauro
I just got an email from Lucy this morning saying they are not ready for sale and she'll let me know when they are.
Offline WA4OPQ
  • 4 stations: 2902 array, GW1000, 3 on Meteobridge
« Reply #19 on: May 19, 2020, 09:47:35 PM »
If you can't wait, the sensor alone is available on Amazon
https://www.amazon.com/dp/B07WV924M8/
Offline GHammer
    • Woodmar Weather
« Reply #20 on: May 20, 2020, 02:50:30 PM »
Sensor alone doesn't do me much good though.
I guess it could be a lovely tie tac...
Offline mauro63
« Reply #21 on: May 20, 2020, 02:56:52 PM »
Mauro
very strange, I have talked today with ecowitt and he send me the new sensor image
I know that they need about 4 weeks to prepare and ship, so I'm confused   #-o
received from ecowitt
Offline WA4OPQ
« Reply #22 on: May 20, 2020, 02:57:54 PM »
I believe there are online instructions to connect it to the WS-2902 or WH32
« Reply #23 on: May 20, 2020, 03:20:28 PM »
Instructions for DIY SHT35 probe soldering is right here:
https://www.wxforum.net/index.php?topic=37849.msg394555#msg394555
Thanks to Raffaello!
« Last Edit: May 20, 2020, 03:45:44 PM by galfert »
Offline GHammer
    • Woodmar Weather
« Reply #24 on: May 20, 2020, 03:36:57 PM »
Mauro
Maybe that's what she meant
As for the new outdoor sensor, sorry that you may still need to wait for several weeks.
We'll let you know when it's available.
Best Regards,
Lucy
