Thanks Galfert!
I don't need the wind or rain data so I would rather not spend the extra money on the 2000 or 2551.
Up to you if you do or don't want a complete system. A complete system is temp, humidity, rain, wind speed, wind direction. Those 5 make up the basis of a basic system. Any less and you may be limited on where you can upload your data...for example if you are missing one of those basic 5. I may be wrong and there is too many different places to test or inquire with and things change all the time. Even if you aren't uploading the data then some weather software may also look for the basic set. Again I may be wrong but you don't see many people around here saying that they don't have a complete set of these 5 basic sensors.
Instead of getting the meteobridge and ambientweather.net license, could I get the "Ambient Weather WEATHERBRIDGE Universal WIFI IP Ethernet Server for Weather Stations?" Same thing?
No, that won't work. The Ambient WeatherBridge does not communicate with any sensor directly....well with the exception of the WeatherBridge PRO (MB PRO)...but I think they stopped selling that (or it is just out of stock) and it was about $465 anyway. But that would only work for Davis sensor stations anyway. The WeatherBridge is like I said earlier just a Meteobridge. The Meteobridge is compatible with a few different brands/models of stations. You can see which stations the standard Meteobridge is compatible with here (but again this requires a station console and sensors):
https://www.meteobridge.com/wiki/index.php/ComparisonCan you tell me what you mean by software expandability?
Software expandability is hardware/software that you add to a station to have it do more than what the manufacture gives you with just their components. The Meteobridge is a form of hardware/software expandability. The Meteobridge allows you to do more with the data from the station....send it to more online services, or log it locally to your own computer, or analyze it locally with that software, or send the data to your own private website....etc.
Realize that even though Ambient sells the WeatherBridge and they sell the WS-2000 and they sell many other models of stuff none of this is made by them. All this stuff comes from other companies (like many many different companies depending on what you are looking at). Ambient is just a reseller of hardware....but they have invested in their own weather network that is supported by the multitude of different hardware that they sell.
Seems like maybe just the GW1000 plus sensors might work for me.
Just the GW1000 with some sensors will work. But it will only send data to: Ecowitt.net, Weather Underground, WeatherCloud, MetOffice WOW, PWSweather*, AWEKAS*, or to systems with other weather software. *You can't send to both PWSweather and AWEKAS at the same time on the GW1000 as there is only 1 custom server destination possible that is compatible with these services. The other services have dedicated built-in configuration settings that you just turn on or off respectively and individually. The "other weather software" are software like I we have mentioned....Meteobridge...but there are other options for software expandability like Cumulus MX, Weather-Display, and WeeWX. With the GW1000 you can run all of these (even simultaneously).
But none of those software will give you IFTTT. The only place I know to get IFTTT is with Ambientweather.net and the GW1000 alone will not upload there....it needs the Meteobridge with Ambientweather.net $100 license....(or a WeatherBridge...but blaaa you give up a ton with the WeatherBridge vs the Meteobridge running on Raspberry Pi ...see earlier Meteobridge comparison chart in regards to TP-Link vs MB RPI 4B)
Well technically speaking there was a recent thread on this forum discussing IFTTT and someone suggested a few other options to get IFTTT but they were not good recommendations as for weather hardware. One was WeatherFlow and the other Netatmo and neither are worth considering. Well I'm allowed to have a preference. Maybe someone else can stick up for either of those two, but certainly not me. I don't even like mentioning them...but if I didn't someone would correct me. Maybe I should find a way to rephrase my IFTTT statement to not need to include these but still be factual.....for example....Ambientweather.net is currently the only recommended network for IFTTT support. There...hmmm....I'll see how that sits for now as statement.
As far as forecast goes, on the typical console sales pictures I see online, there is a small graphic of something like a cloud or sun. Are you saying that that comes from online services? I was thinking it just looked like something the console predicted from the sensors/pressure changes.
Eric
No, that is hokey and useless. Those rain clouds and sun icons on those displays are merely just analyzing what might be possible due to your barometric pressure changes but it is very inaccurate. When I say "dashboard" I'm referring to your data on some online weather service that have crunched data from many stations using various weather forecasting techniques and computer modeling standards.
