Author Topic: Silly question , mutiple GW1000s and multiple external sensors  (Read 895 times)
Online Rover1822
Scenario
With 2 GW1000s, is it possible to set  one to read one external source , and the other a different one?
I'm not concerned with internal readings which the GW1000 will use its own no matter what. Just the external
The external sensors could be rain, wind , whatever.
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
  WittBoy WS90 + GW2000
  WS90 (other one) + GW1100
Personal Sites: Weather Cam
Offline kenthcwx
    • Twitter Account
Re: Silly question , mutiple GW1000s and multiple external sensors
« Reply #1 on: August 27, 2020, 05:15:51 PM »
Scenario
It's possible. It's why some people have two of them, for instance to read the ultrasonic wind sensor on one & the wind cup sensor on the other one to compare.
Froggit WH4000
MeteoShield Professional
Ecowitt WH32-EP
Ecowitt WH51
Ecowitt WH40
Ecowitt WN30
Ecowitt GW1000
Offline Mandrake
« Reply #2 on: August 28, 2020, 03:24:42 AM »
Yep, exactly how I use my systems
G1ZFO
Ecowitt GW2000 (Test)
Ecowitt WS90 Wittboy - Test
Ecowitt WH41 PM2.5 AQM Sensor
Ecowitt WN35 Leaf Moisture
Offline john21283
« Reply #3 on: August 29, 2020, 12:31:57 PM »
Mandrake
Is this a way around the sensor limit in the GW1000? E.g. can i have 8WH51 one GW1000 and four WH51 on a second one? Or am i just being greedy?
Offline Mandrake
« Reply #4 on: August 29, 2020, 01:24:46 PM »
It could be a way around it but there are challenges
The issue you have is that there is no easy way to force the sending sensors to be picked up by one or the other GW1000 if you have more than 8.
You would have to power off the one set of sensors and power on the first GW1000. Once all have registered with the first GW1000 you are free to power it down and those sensors and repeat the setup with the next set.
After that you should be able to power everything back up...however its not cast iron that they will stick but that should work.
I am not sure if anyone on the board has tried this yet, but as you can see it would be a bit of a faff!
G1ZFO
Online Rover1822
« Reply #5 on: August 29, 2020, 01:47:09 PM »
And then there are the issues if you have configured and lose power to the GW1000.
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
