Author Topic: Time Lapse Video not chronologically  (Read 2812 times)
Offline imaduffus
Re: Time Lapse Video not chronologically
« Reply #25 on: December 14, 2019, 02:43:04 PM »
Yes, in germany its nighttime. 8:42 pm
Wondering why I dont see the pictures in filezilla... all folders are empty.
Offline Michael M
    • mypensacolaweather.com
« Reply #26 on: December 14, 2019, 02:44:28 PM »
You clicked on every file and no images showing?
WU
KFLPENSA29  WU is currently Online Again
Got New Station Installed 9-2-22
CWOP DW7066
[AKA]  Michael
Offline Michael M
« Reply #27 on: December 14, 2019, 02:47:58 PM »
Just checked your PWS again and it has a current thumbnail image
Your are good
Let that run for 24 hours
WU
CWOP DW7066
[AKA]  Michael
Offline imaduffus
« Reply #28 on: December 14, 2019, 02:54:03 PM »
I clicked on every folder and all are empty.
Your are good
Yep, will do with 10min upload interval. It runs on 5MP.
Offline awsum140
« Reply #29 on: December 14, 2019, 02:56:09 PM »
Give it some time at 10 min and see what happens.  WU can be a little (lot) slow recovering from over loads.
If it's not a Boerboel it's just a dog.
Offline awsum140
« Reply #30 on: December 15, 2019, 11:07:50 AM »
It looks like you've made some good progress.  The video playback only has a few hiccups now and the image on the control panel appears current, or at least as current as WU can manage.  Maybe slow down uploads a little more and the hiccups will disappear entirely.
Offline imaduffus
« Reply #31 on: December 16, 2019, 09:32:00 AM »
The thumbnails seem to be okay, but the video still has the problems... there are big gaps.
Can you explain me how to see the files in Filezilla? For some reason I can log in but I cannot see the pictures I sent up. So checking file size and trying to reduce is difficult.
On the other hand I checked your cameras and they are not running on 2MP, they are running it a quite shoter intervall and they run really good... I wonder what I can do else... :-(
Offline awsum140
« Reply #32 on: December 16, 2019, 09:38:16 AM »
I don't use Filezilla.  My security software, Blue Iris, handles the uploads.  The source is, indeed, 2MP and I have the file set to 80% of original size.  What I did to determine the file size was also store a local copy on a hard drive.  The "best" size I could determine was in the 200-250KB range.  At least, when I last looked, your images didn't have any big blank spots although there were jumps in the time line that I easily noticed.
Offline Michael M
« Reply #33 on: December 16, 2019, 09:38:43 AM »
Sorry
I will look into it for you later
I will direct message you as soon as i get free today
Im in meetings all day today
WU
CWOP DW7066
[AKA]  Michael
Offline imaduffus
« Reply #34 on: December 16, 2019, 10:42:37 AM »
Hi, I just used the snap tool from reolink cam software and saved the pictures. Still it is not know if this is the size it will actually send up but well, it should be around that.
I have 2 possibilities:
Highest (clear) resolution: 2560x1920 pixels (5MP) 6144 bitrate = 199KB
Lowest (clear) resolution: 2304x1296 pixels (3MP) 6144 bitrate = 128KB
or
Highest (clear) resolution: 2560x1920 pixels (5MP) 1024 bitrate = 183KB
Lowest (clear) resolution: 2304x1296 pixels (3MP) 1024 bitrate = 130KB
Seems bitrate does not influence the picture, but only the video.
even when I setup the cam to fluent setting (1MP 640x480) it does not make a low resolution screenshot with the snapping tool. So my guess is, it transfers one of the 3 settings above which means additionally I cannot make screenshots lower than 3MP.
I am setting up to 3MP with low bitrate. Lets thee what that brings.
Nevertheless, I am below 200KB per picture it seems.. I wish I could really see what the cam loads up.
Offline awsum140
« Reply #35 on: December 16, 2019, 03:01:02 PM »
Keep in mind it takes almost a full day to come into "sync".
Offline imaduffus
« Reply #36 on: December 17, 2019, 01:17:47 AM »
Thanks, I know. I did not touch it for more than 24h and there were problems. Now I am on 3MP and I wait... :grin:
Offline awsum140
« Reply #37 on: December 17, 2019, 04:23:36 PM »
A couple of quick observations.
The time hiccup has moved from at the beginning, early in the clip to right at the end of the clip when I just reviewed it at about 21:30GMT.  That, to me, indicates the "aging" process is, indeed, working and it should disappear by tomorrow morning.
The other thing that has me wondering is that watching your clip, versus mine, it's like yours has had too much caffeine or something.  Playback speed is in the hyper range compared to what I am seeing.  That can be a function of time/file size, differences though.
Offline imaduffus
« Reply #38 on: December 18, 2019, 09:26:38 AM »
The hiccup yep, I see it too.. I will let the setting and wont touch it for a while... thanks for your observations and support.
Offline awsum140
« Reply #39 on: December 18, 2019, 10:34:37 AM »
No more hiccups!  Still at hyper speed though.
I guess you could, if you feel adventurous, try increasing the upload speed a little at a time to see what effect that has.
Offline imaduffus
« Reply #40 on: December 18, 2019, 10:52:36 AM »
https://www.wunderground.com/dashboard/webcam/Imaduffus/2/2019-12-18
I see a hiccup at 18.12. 3am, when it jumps to 17.12. 7pm to 8pm, jumpng back to 3am and going on...
Offline awsum140
« Reply #41 on: December 18, 2019, 11:24:26 AM »
Yup, you're right.  I don't know if that just appeared or was there and I missed it when I looked a while ago.  I'll blame it on tired, old, eyes.
Offline imaduffus
« Reply #42 on: December 18, 2019, 11:58:24 AM »
Dont worry :-)... I just wait and hope the old pictures will fade out... thanks alot for your tight support.
Offline awsum140
« Reply #43 on: December 18, 2019, 04:55:33 PM »
I just looked now, say 22:00GMT, and didn't see any hiccups.  I watched three times to make sure I wan't missing anything.  It looks like you're on a ten minute upload schedule from the playback.
Offline imaduffus
« Reply #44 on: December 18, 2019, 07:37:07 PM »
Hi, yes, 10 min upload right now.
Will check for the next days and maybe change upload interval.
Offline imaduffus
« Reply #45 on: December 20, 2019, 11:44:05 AM »
Okay, it seems, that the hiccups are gone. I am setting the upload interval at 5 mins.
Offline awsum140
« Reply #46 on: December 20, 2019, 02:54:13 PM »
I dunno.  I just watched, twice, and there was a stall almost at the end both times.  Maybe that's when you changed the upload time.
Offline awsum140
« Reply #47 on: December 21, 2019, 11:18:22 AM »
It looks like five minutes might be too fast.  I'd try increasing it by thirty seconds at a time until it smooths out.
Offline awsum140
« Reply #48 on: December 21, 2019, 06:22:33 PM »
Just had a peek again and it seems fairly consistent.  I'm guessing that's a bullet camera and you're using the built-in IR lights.  If you can, shut them off and that will reduce the spider web problem.
Offline imaduffus
« Reply #49 on: December 23, 2019, 04:15:54 AM »
Hi, I did like you told and just removed the LED Lights (IR Lights) and it has hiccups again  ](*,)... well, I am patient.. its xmas time  :lol:... so lets see what will happen in 1 or 2 days...
