Author Topic: Weather Station with Good Radiation Shield  (Read 1312 times)
Offline Matello
« on: June 02, 2025, 02:52:20 PM »
I have a W8686(HP2550 clone). It was my first budget PWS and have been really pleased with it.
The only disapppinting thing has been the radiation shield.
Can anyone recommend a good PWS I can register with ecowitt website that has a good quality radiation shield?
Thanks very much.
Offline Matello
Re: Weather Station with Good Radiation Shield
« Reply #2 on: June 05, 2025, 02:49:39 PM »
Thank you.
Offline alanb
« Reply #3 on: June 05, 2025, 03:18:52 PM »
You could consider adding an Ecowitt WN32 outdoor T/H sensor and locate it in its own radiation shield in a more shaded spot. On the HP2550 display, the WN32 can override the outdoor T/H readiing from the array sensor.
Alan - Ambient WS-2000, Ecowitt GW3000, WH31E x5, WH31L, Ecowitt WN32(WH32E)
          Airthings Corentium Home Radon Detector 223
My station dashboards - WU  AWN  ECOWITT
Offline Matello
« Reply #4 on: June 06, 2025, 02:08:08 PM »
Thanks, I had previously bought one but it turned out to be poor quality. Have had another look and found a much better one  [tup].
Offline vinceskahan
    • home site
« Reply #5 on: June 06, 2025, 03:17:28 PM »
I just took the outdoor Ecowitt sensor and stuck it into a well-vented $10 birdhouse that I painted gloss white and put in the (mostly) shade.  It might get an hour or two sun max during a typical day, but does not heat up at all.
WeeWX sites on a pi4:
  Davis VP2+DFARS
  EcoWitt GW1200, WH32 outdoor T+H, multiple WH31 indoor T+H, WH51 soilMoisture, WH34 soilTemp
  Davis AirLink (inside)
  PurpleAir (outside)
Home site:        https://www.skahan.net/  - sorry, but I block incoming other than US/CA/AU due to bots from elsewhere
Wunderground: KWAFEDER15
PWS:                KWFEDER15
CWOP:              CW6881
Offline Matello
« Reply #6 on: June 06, 2025, 05:21:07 PM »
That's certainly a cheaper solution  [tup]
