Hi all,
The company I work for is looking to set up 3 weather stations across various properties we own. We want to be able to integrate them into a single webpage, making it easier for people at the company to view. I am unsure if we are ok with going cloud-based before the integration or keeping the data exclusively on our network before the integration. I have looked at Davis Vantage Pro2, Vantage Pro2 Plus, and Vantage Vue, with both the wired and wireless options for the Pro2 stations. I reached out to Tempest in regards to their TempestOne stations to see if this would be an option with their stations, and sent an email to METER to explore their options. I also started looking into Ambient Weather stations and ecowitt stations, but we would like as low maintenance as possible because of the locations we will be installing them.
We are not super concerned about cost, but I thought I would see what recommendations you would have as options.
I was planning on using a Google Site to display the data, as this can be restricted to people within our company. Hard-wired options will probably be better as we have login and password-protected Wi-Fi. We can likely make Wi-Fi options work though.
Sensor wise, we are mainly concerned with Temperature, Humidity, Wind Speed and Direction, Rain Fall and Rain Rate, Pressure, and at least one station with UV/Radiation monitoring. At least one station having a Lightning Sensor would be a plus, but not needed.
Thank you for your help!
