Author Topic: W8686(HP2550 clone) not connecting with Ecowitt WS69 array .  (Read 1807 times)
Offline djm
« on: January 18, 2025, 08:16:57 AM »
Hello.Hope you can help.
I am trying to connect a Watson W8686 7" console (a clone of the HP 2550 from  Ecowitt)with  a new replacemnent Ecowitt WS69 Wireless 7-in-1 Outdoor Sensor Array but they are not connecting.Both are 868mhz.
On the console sensor ID list there is no WS69.I bought the replacement array as i was convinced it would connect to the  console .Any help would be appreciated.Thank You.
Online R.Sidetrack
Re: W8686(HP2550 clone) not connecting with Ecowitt WS69 array .
« Reply #1 on: January 18, 2025, 09:08:26 AM »
Well, start with the basics.   How far apart do you currently have these two devices?  Are there walls or other obstacles  in between?   Do you have fresh, brand name quality batteries in the sensor unit?
Do you have the "WSView  Plus" app installed on a phone? If not, install that app.
Graham
--- Variety of 'discrete' Ecowitt devices; CumulusMX on Raspberry Pi4 ---
Offline djm
« Reply #2 on: January 18, 2025, 09:41:18 AM »
Thanks for responding,
Both devices in same room.New batteries in both.I,ve downlaoded WSView  Plus on my phone.
Online R.Sidetrack
« Reply #3 on: January 18, 2025, 10:08:56 AM »
When you open the app, do you see the Watson W8686 visible in the  app  under "My devices"?
Graham
Offline djm
« Reply #4 on: January 18, 2025, 10:26:31 AM »
Yes it does but when it asks to place !Gateway in  wi-fi configuration Mode" im lost im afraid.
Online R.Sidetrack
« Reply #5 on: January 18, 2025, 11:05:17 AM »
A member here developed a Wiki that should be useful. https://meshka.eu/Ecowitt/dokuwiki/doku.php?
Once the page loads, look to the Table of Contents on the right side. Scroll down to the "5.2 procedure" and click that. See the attached screenshot.
That should get you to the section headed "5.2 procedure" which is about WiFi configuration. Read the whole section first.  Then go back and actually do the steps.
You will need to disconnect from your normal wifi network because the gateway will establish its own (temporary) network that you will need to connect to.  After the gateway is configured the temporary network goes away and you can the reconnect to your normal network.
This can be confusing if you have not encountered this kind of process previously. :)
« Last Edit: January 18, 2025, 11:07:53 AM by R.Sidetrack »
Graham
