Author Topic: Incorrect outside temperature  (Read 418 times)
Offline Les
« on: May 18, 2024, 08:24:32 AM »
VWS, Win10, Ultimeter U2100.    Only recently noticed that the outside temp is actually displaying +>5. Searching a method to pre load a correction via VWS. Is this possible or should just go ahead and replace the sensor?
TIA
Les./G0NXI
Offline Andy Thompson
  • Southern Minnesota Live Weather
  • Madelia and Thompson Farms
Re: Incorrect outside temperature
« Reply #1 on: May 20, 2024, 07:20:02 AM »
5 degrees off seems like a lot. I would look into calibrating the sensor. If you canít calibrate it then replace it. Offset the reading as a last resort.
Regards,
Andy Thompson
www.somnwx.com
Offline Les
« Reply #2 on: May 20, 2024, 01:38:35 PM »
Good advice - thanks Andy.
Offline Mattk
« Reply #3 on: May 20, 2024, 04:38:21 PM »
What is the +5 deg compared to?
Offline Aussie Susan
« Reply #4 on: May 20, 2024, 10:30:51 PM »
Perhaps not relevant but my outdoor sensor is definitely incorrect when the humidity is about ~97%.
What is your humidity at the time the reading is high?
Susan
