Author Topic: ipwx-raspi-weewx station setup questions  (Read 18709 times)
Offline mikez104
Re: ipwx-raspi-weewx station setup questions
« Reply #50 on: May 06, 2015, 08:21:11 PM »
I was looking through the parser program and trying to figure out how that works.  It looks pretty straight forward.  I also was looking at the data that comes in from the listener. I can understand most of it.  Seems like the values of the readings are prefixed with an A ans some of them have a lot af extra 00s at the end.  Delimited with a &.  And you spell out the compass rose weirdness with the hex and the wind in cm/sec but what the heck is going on with the pressure?  Looking at the raw data, I just don't get how you can get anything from that.  How did you figure that one out?  Or am i missing something.
Offline nincehelser
« Reply #51 on: May 06, 2015, 08:37:39 PM »
Figuring out the the pressure data took a little bit of detective work and educated guessing.  I started searching data sheets for baro sensors that had similar characteristics.  It didn't take too long to find one where the number and names of the variables matched up.  I ran the numbers through the equations on the data sheet and found the results matched up perfectly.  A bit later another hacker disassembled their bridge and visually verified that the sensor and data sheet lined up.
http://www.hoperf.com/upload/sensor/HP03S.pdf
Offline aweatherguy
    • Weather Station Data Logger
« Reply #52 on: May 18, 2015, 02:29:33 AM »
Others have done the RF signal decode. Try an internet search for "acurite 5n1 rf decode" to find some of them.
The rain is indeed just a counter that increments by one for every bucket tip. It is probably 13-bits wide so would count from zero to 8192 (or 81.92 inches of rain) before rolling over.
Offline nincehelser
« Reply #53 on: May 18, 2015, 07:36:25 AM »
Unfortunately that is not how the data comes out of the Acurite Bridge.
Offline aweatherguy
« Reply #54 on: May 18, 2015, 09:30:31 PM »
Sorry, just trying to help. Earlier in this thread you said:
The big question is what data the 5n1 is actually sending out the radio link.  I don't know of anyone who has decoded it that far.  Basically the 5n1 has a counter to count the bucket tips.
And I knew the radio link has been figured out so was trying to provide that info.
Offline mikez104
« Reply #55 on: May 18, 2015, 09:56:10 PM »
I tried to pull my 5n1 off the pole today to experiment with the rain buckets.  When I tried to unscrew the screw I put in to to fix the 5n1 to the pole, I snapped the head off.  :?
Yup, stainless stud sticking out of the pole securely fixing the plastic base in place.  I didn't feel like drilling it out as we were thunderstorms were on the way.  We ended up getting almost an inch and a half of rain.  Anyway, here is the question.
Do you think there is a way to read an additional sensor in the parser program?  The windspeed from my 5n1 is too low.  It is not that high up and there are trees all around.  I still have a Davis anemometer on my roof from my old system.  It still spins and is unobstructed and is 40ish feet above ground.  I got hold of the wire from the thing and spliced it to an arduino.  It reads the closures of the switch and counts them and calculates a wind speed.  The guy who came up with the program had it sending the windspeed and temp to an LCD.  I got rid of the temp code he had in there and changed it to write to the serial port instead of the LCD.  I hooked that up and can see the data on the Raspi by doing a cat /dev/ttyACM0.  Right now I have it outputting "Windspeed is XX" but could change that to anything.  The Arduino script counts the pulses for 3 seconds then averages and gives the speed.
The readings I was getting with the Davis unit were almost twice as the 5n1 and they also were very close to the guy up on the hill behind my house.  He has a weewx site also and uses a Davis Vantage Pro2.
So, not sure how much would be involved in adding that.  Let me know what ya think.
Mike
Offline nincehelser
« Reply #56 on: May 18, 2015, 10:14:58 PM »
Mike
That shouldn't be too hard.
Quick and dirty, just before the wxdata file is written, I'd read the windspeed using /dev/ttyACM0 as the input and write that value to wxdata instead of the value from the 5n1.
Offline mikez104
« Reply #57 on: May 19, 2015, 06:16:23 PM »
One would think that would be easy...  and it may be if you know how to program.  Unfortunatly I do not.  I looked around for some code and found some that works but it reads the usb port forever and never moves on to write the file.  Here is what I have.  I added this to the top and it seems to work fine.
use Device::SerialPort;
my $port = Device::SerialPort->new("/dev/ttyACM0");
$port->databits(8);
$port->baudrate(9600);
$port->parity("none");
$port->stopbits(1);
But here is where I am stuck.  The original code reads like this, and it loops forever.
while(1) {
  my $byte=$port->read(1);
  print "$byte";
If I try this, it just errors out and I'm not sure where to go from here.
$windspeed = $byte
Offline mikez104
« Reply #58 on: June 06, 2015, 01:53:42 PM »
Hey George, Have you ever run into this one?  My raspberry pi was unresponsive this morning so I power cycled it and when it came back up it looked at the syslog and this is what it is doing when it tries to start weewx.
Jun  6 13:47:01 weatherpi /USR/SBIN/CRON[2775]: (root) CMD (/home/ipwx/./watchdog)
Jun  6 13:47:02 weatherpi weewx[2793]: engine: Initializing weewx version 3.1.0
Jun  6 13:47:02 weatherpi weewx[2793]: engine: Using Python 2.7.3 (default, Mar 18 2014, 05:13:23) #012[GCC 4.6.3]
Jun  6 13:47:02 weatherpi weewx[2793]: engine: pid file is /var/run/weewx.pid
Jun  6 13:47:02 weatherpi weewx[2795]: engine: Using configuration file /etc/weewx/weewx.conf
Jun  6 13:47:02 weatherpi weewx[2795]: engine: Loading station type Simulator (weewx.drivers.simulator)
Jun  6 13:47:02 weatherpi weewx[2795]: engine: StdConvert target unit is 0x1
Jun  6 13:47:02 weatherpi /USR/SBIN/CRON[2774]: (CRON) info (No MTA installed, discarding output)
Jun  6 13:47:02 weatherpi weewx[2795]: engine: Archive will use data binding wx_binding
Jun  6 13:47:02 weatherpi weewx[2795]: engine: Record generation will be attempted in 'hardware'
Jun  6 13:47:02 weatherpi weewx[2795]: engine: Using archive interval of 60 seconds
Jun  6 13:47:02 weatherpi weewx[2795]: engine: Caught unrecoverable exception in engine:
Jun  6 13:47:02 weatherpi weewx[2795]:     ****  database disk image is malformed
Jun  6 13:47:02 weatherpi weewx[2795]:     ****  Traceback (most recent call last):
Jun  6 13:47:02 weatherpi weewx[2795]:     ****    File "/usr/share/weewx/weewx/engine.py", line 831, in main
Jun  6 13:47:02 weatherpi weewx[2795]:     ****      engine = EngineClass(config_dict)
Jun  6 13:47:02 weatherpi weewx[2795]:     ****    File "/usr/share/weewx/weewx/engine.py", line 77, in __init__
Jun  6 13:47:02 weatherpi weewx[2795]:     ****      self.loadServices(config_dict)
Jun  6 13:47:02 weatherpi weewx[2795]:     ****    File "/usr/share/weewx/weewx/engine.py", line 141, in loadServices
Jun  6 13:47:02 weatherpi weewx[2795]:     ****      self.service_obj.append(weeutil.weeutil._get_object(svc)(self, config_dict))
Jun  6 13:47:02 weatherpi weewx[2795]:     ****    File "/usr/share/weewx/weewx/engine.py", line 504, in __init__
Jun  6 13:47:02 weatherpi weewx[2795]:     ****      self.setup_database(config_dict)
Jun  6 13:47:02 weatherpi weewx[2795]:     ****    File "/usr/share/weewx/weewx/engine.py", line 602, in setup_database
Jun  6 13:47:02 weatherpi weewx[2795]:     ****      dbmanager = self.engine.db_binder.get_manager(self.data_binding, initialize=True)
Jun  6 13:47:02 weatherpi weewx[2795]:     ****    File "/usr/share/weewx/weewx/manager.py", line 833, in get_manager
Jun  6 13:47:02 weatherpi weewx[2795]:     ****      self.manager_cache[data_binding] = open_manager(manager_dict, initialize)
Jun  6 13:47:02 weatherpi weewx[2795]:     ****    File "/usr/share/weewx/weewx/manager.py", line 915, in open_manager
Jun  6 13:47:02 weatherpi weewx[2795]:     ****      manager_dict['schema'])
Jun  6 13:47:02 weatherpi weewx[2795]:     ****    File "/usr/share/weewx/weewx/manager.py", line 139, in open_with_create
Jun  6 13:47:02 weatherpi weewx[2795]:     ****      dbmanager = cls(connection, table_name=table_name, schema=schema)
Jun  6 13:47:02 weatherpi weewx[2795]:     ****    File "/usr/share/weewx/weewx/manager.py", line 1052, in __init__
Jun  6 13:47:02 weatherpi weewx[2795]:     ****      super(DaySummaryManager, self).__init__(connection, table_name, schema)
Jun  6 13:47:02 weatherpi weewx[2795]:     ****    File "/usr/share/weewx/weewx/manager.py", line 71, in __init__
Jun  6 13:47:02 weatherpi weewx[2795]:     ****      self.sqlkeys = self.connection.columnsOf(self.table_name)
Jun  6 13:47:02 weatherpi weewx[2795]:     ****    File "/usr/share/weewx/weedb/sqlite.py", line 151, in columnsOf
Jun  6 13:47:02 weatherpi weewx[2795]:     ****      column_list = [row[1] for row in self.genSchemaOf(table)]
Jun  6 13:47:02 weatherpi weewx[2795]:     ****    File "/usr/share/weewx/weedb/sqlite.py", line 140, in genSchemaOf
Jun  6 13:47:02 weatherpi weewx[2795]:     ****      for row in self.connection.execute("""PRAGMA table_info(%s);""" % table):
Jun  6 13:47:02 weatherpi weewx[2795]:     ****  DatabaseError: database disk image is malformed
Jun  6 13:47:02 weatherpi weewx[2795]:     ****  Exiting.
I saw someone said you may be able to fix this by using sqlite to dump to a text file then reimporting.  I tryed that but it would bnot dump.  Here's what I got.  Any clue how to repair this db?  Or what may have caused the corruption in the first place?  It happened this morning at about 6:30.  No power hits or anything, the box just locked up at that time.
PRAGMA foreign_keys=OFF;
BEGIN TRANSACTION;
/****** CORRUPTION ERROR *******/
/****** database disk image is malformed ******/
/****** ERROR: database disk image is malformed ******/
/**** ERROR: (11) database disk image is malformed *****/
ROLLBACK; -- due to errors
Offline nincehelser
« Reply #59 on: June 06, 2015, 02:47:15 PM »
I haven't had that happen before.  If the Pi was completely locked up, I suspect something went wrong when writing to the SD card.
Be sure your Pi's power adapter can supply plenty of power.  The only crashes I have had were due to a wimpy adapter I was trying to use (only .5 Amp).
You might try the weewx users group for ideas on repairing the database file.
Offline mikez104
« Reply #60 on: June 11, 2015, 11:17:54 PM »
maybe it it the card, idk.  It went weird on me again tonight.  It has done this before.  Apache stops responding, I can't ssh in and things get weird.  I was able to blindly hook up a keyboard and gracefully shut it down and reboot.  I swapped the power supply for a 3 amp unit.  We'll see what happens...
Offline mikez104
« Reply #61 on: June 11, 2015, 11:19:04 PM »
BTW, that turtle in your signature thing looks like it would take your hand off!
Offline nincehelser
« Reply #62 on: June 11, 2015, 11:28:12 PM »
It almost did!
It lunged out at my iPhone right after I took that shot.  Knocked it clean out of my hands and put a good gouge in the case!
But now no one should mess with my phone again!
« Last Edit: June 12, 2015, 12:33:11 AM by nincehelser »
Offline yahtah
  • Too soon old, too late smart.
« Reply #63 on: September 12, 2015, 11:42:20 PM »
Turtle Soup?
-Lee
Davis VP2, Meteostick, RPi Meteohub, KCACALIF33
working on an RPi webcam and a 30 ft. flagpole...
