Weather Software => What Weather Software should I use/buy? => Topic started by: GeoAir.pt on December 26, 2017, 09:12:43 AM
Hello, season greetings.
Is there any proven solution to run weatherlink 6.0.3 (firmware 1.9) and other weather apps simultaneously in a win10 x64 environment ?
I have seen references to VirtualVP, VSPE-Virtual Serial Ports Emulator, com0com, and others, but i can't find a working solution for w10 x64.
Any suggestions?
Thank you
Edit: Weatherlink runs with usb datalogger
VVP is the best solution
since you have an older firmware , it should work hopefully
have you tried it?
Thank you for your suggestion.
Managed to install VVP and successfully communicating with davis vantage pro console.
Since that I'm using a 64bit environment , whats the suggested method to create the virtual com ports, considering that VSPE in 64x version is paid?
Best regards.
