Author Topic: Display on WH32ep is not working  (Read 305 times)
Offline Platokidd
  • top side land of Lincoln
« on: April 22, 2024, 07:46:35 AM »
The screen on my wh32ep started acting up and not showing normally. So far, the temp and humidity from the sensor is still working.
Temps have been lows in the mid 30's f at night to highs in the 60's f during the day.
Have to wonder how long it will continue to work..
« Last Edit: April 22, 2024, 07:50:59 AM by Platokidd »
Ambient
ECOWITT
1-HP10 2-WH45 1-WH46 4-WH55
1-WN30 1-WH41 5-WH51
1-DAVIS 7714
1-STRATUS
1-Fisher Barometer 1436R-22
1-Starpath Baro
PWS at 2 locations.
Offline Gyvate
Re: Display on WH32ep is not working
« Reply #1 on: April 22, 2024, 12:58:59 PM »
How old is your WH32-EP ?
Mine showed the same phenomenon - the LCD panel stopped displaying after 2+ years (it looked as if water had entered which was of course not the case), but the readings were not impacted.
Ecowitt sent me a replacement display (very easy to replace) on request along with my next order.
MeteobridgePro(2)[test,prod] 5.8 Mar 01 2024, 15185 - Blake-Larsen Sun Recorder - RPi4/weewx 4.8.0/4.10.2/CumulusMX 3283/Meteobridge RPi4B-2GB,
Barani Meteoshield Pro, MetSpec Rad02
weather landing page: http://meshka.eu
WIKI http://meshka.eu/Ecowitt/dokuwiki
Offline Platokidd
« Reply #2 on: April 22, 2024, 10:26:49 PM »
Interesting. My wh32ep is 2 1/2 years old. I'll reach out to Ecowitt about a new screen. Thanks
Ambient
ECOWITT
1-DAVIS 7714
1-STRATUS
1-Starpath Baro
PWS at 2 locations.
Offline Platokidd
« Reply #3 on: April 26, 2024, 01:25:10 PM »
The new screen is on the way. I can do easy, assume one needs to open up the case and pop out/in the screen. Is it a plug in /out screen? Or will this require soldering?
Ambient
ECOWITT
1-DAVIS 7714
1-STRATUS
1-Starpath Baro
PWS at 2 locations.
Offline Gyvate
« Reply #4 on: April 26, 2024, 01:50:13 PM »
no soldering involved - just remember how you took it out - put the new one in in reverse order - make sure it's fitting tighly for the numbers to appear ...
You can take one of your WH31 and open it to see how the display is connected ...
