Author Topic: WN32CP Temperature Humidity Pressure sensor  (Read 611 times)
Offline Rocketman
« on: January 27, 2023, 03:46:02 AM »
Just got WN32CP with my Pantech WS off eBay . Just wondered why the sensor is not listed on the Ecowitt site ?
HP2550 console 1.9.3 , WS80 1.2.4 , WH57 lightning sensor , WH40 rain gauge , WH51 soil moisture sensor , GW1100 gateway 2.3.0
Offline olicat
    • FOSHKplugin
Re: WN32CP Temperature Humidity Pressure sensor
« Reply #1 on: January 27, 2023, 04:00:34 AM »
Hi!
This is just another name for the WH32B aka WH32 indoor.
WN and WH are sometimes used synonymously.
C = 433MHz
P = pressure
Oliver
Offline Rocketman
« Reply #2 on: January 27, 2023, 01:17:38 PM »
Using gw1100 this device doesn’t appear on the device list . How do I select it ?
Offline olicat
    • FOSHKplugin
« Reply #3 on: January 27, 2023, 01:36:19 PM »
Hi!
Unless you cut the cable with the sensor from the GW1100, you will not be able to pair the WH32B with the GW1100.
Oliver
Offline kheller2
« Reply #4 on: January 27, 2023, 02:47:02 PM »
To elaborate on what Oliver said...
The GW1100 already has an indoor Temp/Hum/Pres sensor on the attached cable, so it will not use any other duplicate sensor.
[unless you cut the cable, in with case the firmware starts looking for the external one -- assuming your GW1100 is also 433MHz]
I believe there are some threads on here on how to convert the WH32 to be an outdoor sensor (minus pressure), overriding your array if need be.
Ambient Consoles: WS-2000, WS-1900, WS-1200, WS-2902C, WS-3000-X3, WS-0900-IP(observerIP), WS-1001-WIFI
Ambient Arrays: WH65B
Ambient Sensors: WH31E(3), WH31B(2), WH32B, WH31SM(2), WH31PGW, AQIN, WH31LA(3)
Ambient Spares: WH24B(2), WH25B.
Ecowitt: HP2551BU, GW1000B(dead), GW1100B(2), GW2000B
Ecowitt Sensors: WH51, WN34BL, WN34(2), WH31, WH41, WH40
Offline Rocketman
« Reply #5 on: January 27, 2023, 03:03:45 PM »
No problem , I'll just use the existing one ( just playing around )  [tup]
« Last Edit: January 27, 2023, 03:05:47 PM by Rocketman »
Offline Platokidd
  • top side land of Lincoln
« Reply #6 on: January 27, 2023, 03:33:32 PM »
Hi!
Oliver
Interesting. So, may I assume the indoor wh32b will just appear in the sensor setting for the gw1100?
Does the same hold true for the gw1000 and gw2000?
« Last Edit: January 27, 2023, 03:36:20 PM by Platokidd »
Ambient
ECOWITT
1-HP10 2-WH45 4-WH55 5-WH51
1-WN30 1-WH41
1-DAVIS 7714
1-STRATUS
1-Fisher Barometer 1436R-22
PWS at 2 locations.
Offline BoDuke
  • Ambient Weather, Ecowitt, WeeWX, Custom PHP
« Reply #7 on: January 27, 2023, 04:35:47 PM »
Yes, the GW1000, GW1100, and GW2000 can be physically modified so they no longer use the wired sensors and can use a WH32 indoor (WH32B) sensor instead.  It might also work on the HP2560 console but to my knowledge, this has not been verified yet.
Here are two topics where this is discussed:
https://www.wxforum.net/index.php?topic=43781
https://www.wxforum.net/index.php?topic=44706
Offline Rocketman
« Reply #8 on: January 27, 2023, 04:40:36 PM »
I guess it will according to latest firmware , but it doesn't have channel selection ( assume it will be channel 1 )
Offline BoDuke
« Reply #9 on: January 27, 2023, 04:43:46 PM »
The WH32B will appear as the barometer/pressure and indoor temperature.  There are no channels on WH32, only on WH31 and various other types of sensors.
Offline Platokidd
« Reply #10 on: January 27, 2023, 05:11:08 PM »
son of a gun.. I just snipped the wire.  Less than a minute it showed up and started working on my gw1100.
« Last Edit: January 27, 2023, 05:13:28 PM by Platokidd »
Ambient
ECOWITT
1-WN30 1-WH41
1-DAVIS 7714
1-STRATUS
PWS at 2 locations.
Offline kheller2
« Reply #11 on: January 29, 2023, 10:15:45 PM »
Sweet.   But to be safe I would make sure those wires don’t short together.  Either desolder them, or cut the internal wires at various lengths and tape.
Offline Rocketman
« Reply #12 on: January 30, 2023, 12:03:01 AM »
Or put a switch in maybe triple pole
Offline Gyvate
« Reply #13 on: January 30, 2023, 03:29:59 PM »
it's converting a WH31 into a WH32 outdoor (Ecowitt notation), works, has been shown with the old and the new PCB (printed circuit board  8-) - not the Chemical) - and vice versa.
Maybe also a WH32B (WH32 indoor, Ecowitt notation) into a WH32 outdoor - don't recall the latter.
