Author Topic: proper procedure when moving  (Read 915 times)
Offline WA7FWF
  • Blitzortung 1196
« on: January 07, 2016, 10:45:19 AM »
   Whats the proper procedure when moving? just change location information in the services panel? or delete the station from database and get a new station number assigned? looked around and searched but have not found anything covering this.
Kevin 1196
Re: proper procedure when moving
« Reply #1 on: January 07, 2016, 01:22:11 PM »
I moved almost two years ago. As I recall, I just changed the City name, etc. The system picks up your GPS coordinates so actual position is handled automatically when you move. I am still using my same station numbers as before.
Offline WA7FWF
  • Blitzortung 1196
« Reply #2 on: January 08, 2016, 01:32:50 AM »
Thanks for the info just thought I would check and make sure, another month and its up to northern Idaho, guess I better start planning on a heater for the rain gauge...  :-)
