One additional thought, stimulated by Mike's post above:
If you could determine the quality of the output of the TOGA measurement for each lightning receiver, you might be able to use a technique called "weighted least squares" to improve the final stroke location estimate. There's an article on Wikipedia about least squares that includes a section on weighted least squares; you can find it at
http://en.wikipedia.org/wiki/Least_squares#Weighted_least_squares . A fairly obvious factor that might make one want to weight a particular station's measurements lower, at least on one channel, is the presence of strong interference at that station. That's pretty easy to detect in the spectra of the received signals. (Sorry, you guys near Fort Collins, Cutler, Jim Creek, etc.)
I stopped working in the navigation field in the early 1980's, and it would take me some time to get up to speed on weighted least squares. Moreover, I want to spend my remaining use-or-lose leave time on another hobby project. I have an idea of how I'd modify my Excel VBA code to test the implementation of weighted least squares suggested above that I'd be willing to share, though.
A final note: I haven't had any discussions with Egon, Richo, or Tobi about any of this, so I have no idea of what algorithms they're using (other than TOGA). I don't have a lot more time to spend on this. I just wanted to refresh my memory on the least-squares technique, see if I could modify it for a system like the Blitzortung system, and get it to the point where I could share it with my fellow hobbyists.
Chip
