Yep!(Click to enlarge)Now, my project between now and Spring for will be updating the 'old'
http://frankfortweather.us/BoStaSigsources to reflect changes. That
Region 3 'subsite' had apparently helped may of us optimize our stations last summer.
Note that
some of the currently listed stations are working under the older code, not all,
and it's not likely to be permanent.... Also
most of the newer stations on BO net aren't implemented...
that is, those who activated after 09/14/2014 ± (arrgggh... dread that updating),...
Possibly integrating with an experimental concept
http://frankfortweather.us/mapper/Only KY, OH, TN, and Lonesome Stan in Maui are currently active on the test mapper
Matter of fact, this current data sourcing may not be permanent. Egon has more refinement and work to do, and
there are a couple of bugs. (e.g. 'sig/noise'?) Also, I don't think "Green" stations are included, for now, in the '
revived' BO page signal...
...or weren't at the time Egon 'reactivated'... some such, anyway. I think there is also some signal info the developers
would like to have displayed... so this is likely not the "permanent" version by any means...
It's possible we will go through something similar as 3rd generation BO system ("Blue"?
) releases in Spring/Summer 2015
as that system will supply some different signals and processing...
Mike
