Author Topic: newbie needs help  (Read 800 times)
Offline WA7FWF
  • Blitzortung 1196
newbie needs help
« on: October 08, 2014, 10:31:41 PM »
Got my E field built and hooked up everything seemed to be OK and then I had a power hiccup here, since then the station detects strikes and or noise  and I can log into it locally  and see the signals but its not connecting out, on the lcd screen station id and user id are both 0, I have been all over trying to find where I can set that.
any clues please...
Kevin
Offline WA7FWF
  • Blitzortung 1196
Re: newbie needs help
« Reply #1 on: October 08, 2014, 10:58:42 PM »
more info.. turning on debug and looking at the logs
2014-10-09 02:53:42   1835 | REMOTE-CONFIG: IP to hostname www.lightningmaps.org NOT found ...
2014-10-09 02:53:42   1835 | REMOTE-CONFIG: Server 1 ERROR. All servers:
2014-10-09 02:53:42   1835 | REMOTE-CONFIG: Server 0, Status 5, URL "http://tracker.blitzortung.org/control/station.php"
2014-10-09 02:53:42   1835 | REMOTE-CONFIG: Server 1, Status 5, URL "http://www.lightningmaps.org/control/station.php"
2014-10-09 02:53:42   1835 | REMOTE-CONFIG: Server 2, Status 1, URL ""
2014-10-09 02:53:42   1835 | REMOTE-CONFIG: Switched to server #0
2014-10-09 02:53:43   1836 | REMOTE-CONFIG: Server switched to 0
2014-10-09 02:53:49   1842 | REMOTE-CONFIG: IP to hostname tracker.blitzortung.org NOT found ...
2014-10-09 02:53:49   1842 | REMOTE-CONFIG: Server 0 ERROR. All servers:
2014-10-09 02:53:49   1842 | REMOTE-CONFIG: Server 0, Status 5, URL "http://tracker.blitzortung.org/control/station.php"
2014-10-09 02:53:49   1842 | REMOTE-CONFIG: Server 1, Status 5, URL "http://www.lightningmaps.org/control/station.php"
2014-10-09 02:53:49   1842 | REMOTE-CONFIG: Server 2, Status 1, URL ""
2014-10-09 02:53:49   1842 | REMOTE-CONFIG: Switched to server #1
dns is the default 8.8.8.8  also tried another dns server same result, ping the website via a command prompt replies back with the correct ip so I'm not sure what is happening here...
Offline WA7FWF
  • Blitzortung 1196
« Reply #2 on: October 08, 2014, 11:07:41 PM »
I knew as soon as I posted something I would find it... sorry for the bandwidth...  turns out my NVG510 at&t modem had something against me...  I run static I.P.'s here and as soon as I changed the I.P. bam it all took off
 :oops:   kevin
