Author Topic: Red Firmware 6.4 released - 1/22/2014  (Read 832 times)
Offline W3DRM
    • Emmett Weather
« on: January 22, 2014, 02:45:49 PM »
A fix to the problems with 6.3 has been released this morning. I installed it using the STM32 ST-Link utility and it went in without any problems at all. Got a GPS lock in less than 60 seconds and smoothing values shortly after that.
Tobi also added a new GPS satellite map to the GPS screen which is very nice (as usual).
I had to use the ST-Link utility because I had installed 6.2 and couldn't use the web interface. Hopefully that is now fixed. Will find out when the next up firmware update comes out...
Davis Wireless VP2, WD 10.37s147,
--- RIPE Atlas Probe - 32849
Re: Red Firmware 6.4 released - 1/22/2014
« Reply #1 on: January 22, 2014, 06:17:39 PM »
Just used the web interface on 6.3 to successfully update to 6.4
Bonus: the GPS was smoothed in 9 seconds and fully online in less than a minute.
Offline W3DRM
    • Emmett Weather
« Reply #2 on: January 22, 2014, 06:33:33 PM »
Glad to hear it worked "as intended" for you Ken. I have noticed since installation that my Red amp gains are more closely matched to each other (10*2*40) and so far, seem to be higher than they were prior to 6.x. The thresholds are lower than I had manually set them though. Guess that is how Tobi has programmed it to be to increase the sensitivity.
I hope to get my antenna moved out of my office later this week. Am thinking about placing it outside in a home-built wooden box so it is away from my electrical noise in the house. So far, I haven't been able to find an electrically quiet place anywhere inside, including my attic space. I need to take advantage of this dry weather we are having before the thunderstorms start-up in the Spring and Summer months.
