Not sure. I did upgrade from v5.0 and had pretty vanilla settings from what I can tell. Based on the note I saw on the Blitzortung forum, I had written down my settings prior to the upgrade so it only took a few minutes to review them and get them back to where had been.
Am wondering if it had something to do with my unit coming up in "Automatic" mode when it rebooted? That may have forced settings to be changed and then automatically saved which would have overwritten my original settings.
Here is what I see when I select Automatic mode:
- Remote Control
Mode:
Automatic Mode: Blitzortung.org servers try to find the best settings for your station. You don't have to worry about gain and other settings. The controller does not store any of those remote values in flash! You can see the current values on the "Status" page. See documentation which parameters could be transmitted (coming soon).
Note: This feature is currently in a early beta stage on the server side. It will take some time to adjust this feature. Have a look into our forum for latest news about it.[/b]
The wording above contradicts statements on the B forum that it hasn't been implemented yet.
Uh-oh, just noticed that my firmware upgrade apparently did NOT install. I see it still shows as being the old rev level:
- Controller / CPU
Firmware Rev. 5.0 / Dec 1 2013 11:20:02 (Git: 5.0-0-gd68f531)
Hardware Rev. 10.3 (PCB-Id 1)
Device-ID 3E00-3100-0747-3133-3235-3735
HCLK / SYSCLK / PCLKs 168 / 168 / 42 / 84 MHz
CPU 24%, 40.2°C, 2.95V
Max. Memory usage 81kB + 65kB for Signals
Signal Buffers 32, 1 currently used
Input Voltage 4.97V
Am going to try to reload the v6.0 firmware as see what happens. Back in a bit...
