Author Topic: Ferrite antenna placement  (Read 1075 times)
Offline Jumpin Joe
    • Joe’s Weather
« on: September 14, 2013, 10:26:33 PM »
I bought the ferrite antennas from Egon and want to know if anyone has tried placing them in an attic? The attic gets pretty hot in the summer. If I can, do I also place the board there and run a cat 5 cable to my PC?
Joe
https://joesweather.info
WeatherLink Live
Re: Ferrite antenna placement
« Reply #1 on: September 15, 2013, 07:39:49 AM »
Joe,
The ferrite antennas themselves should have no problem with attic temperatures.
I was more concerned about the electronics. The PGAs have a 125C rating and everything else seems to be rated to 85C (industrial temp). On the cold end the parts look to be good to -40C.
I saw some references about attic temperatures hitting 180F which is close to the rating. If you have effective roof vents I would think that it would be lower than this.
« Reply #2 on: September 15, 2013, 07:43:10 AM »
Joe,
I see that you are in Ohio. The info I found that mentioned the 180F was out West.
http://www.inspectionnews.net/home_inspection/attic-areas-home-inspection-commercial-inspection/21247-attic-temperatures.html
Offline Jumpin Joe
    • Joe’s Weather
« Reply #3 on: September 15, 2013, 08:52:31 AM »
Hi Greg,
Yep, right where the Greyhound bus flipped over yesterday. I was more concerned with the performance than the temp.
Thanks for the information.
Joe
WeatherLink Live
