Author Topic: Oh Great, looks like chunks of 'forecast.weather.gov' are down  (Read 2604 times)
Offline Jstx
  • Baby the Rain Must Fall
Most of the point forecast WFO and ASOS Current Observations are showing "NULL" or "NA" for Central and South Texas now.
Happening elsewhere?
Offline BrianLehan
    • Grace C Lehan Memorial Weather Station
Re: Oh Great, looks like chunks of 'forecast.weather.gov' are down
« Reply #1 on: June 01, 2018, 11:26:06 PM »
Same up here in Connecticut most of this past week.
The detailed point forecast weather data is not currently available.
The zone forecast data for CTZ002 (Hartford) will be displayed
until the point forecast data is again available.
If this persists, contact the NWS Boston / Norton, MA WFO
at 508.622.3250 or email at box.webmaster@noaa.gov
to have them update the point forecast for /gridpoints/BOX/18,39 on api.weather.gov
I think its due to more continuing issues with the weather.gov api in use at the moment. If I go to the map myself the forcast is the same as what the script is picking up, only the link to pin point is missing. I have other cities such as San Fransisco, LA in my pull-down and they all say the same message basically.
Brian
Davis Vantage Pro 2 plus
VWS 15x on Windows 7
Sarasota-Weather Template
Gr3 Radar
« Reply #2 on: June 02, 2018, 11:46:07 AM »
Make sure you're running the 5.09 version of advforecast2.php (JSON) -- there were issues with prior versions detecting a point forecasts (due to changes in the JSON returned by api.weather.gov.
Offline BrianLehan
« Reply #3 on: June 03, 2018, 08:53:35 PM »
Thanks Ken.
That fixed a many of the forecasts for locations in my pull-down's, so I guess the others really are not available.
Brian
Gr3 Radar
« Reply #4 on: June 03, 2018, 09:53:44 PM »
Try adding a ?force=1 to the URL you see in the browser on the feeds having an issue. That forces a cache refresh for the point forecast.  If you still see the zone forecast and message, then the point forecast really isn’t available at that time.
Offline richpuch
    • Pompton Plains Weather
« Reply #5 on: August 17, 2018, 09:27:49 AM »
Having a similar problem...almost similar.  My local forecast hasn't been updated since 7/31, all my other pulldowns are up to date?  If I manually take the URL from Settings.php and input into browser I get the current forecast.  Is there a cache somewhere local on my server, or is it on NWS side?
http://weewx-wd.puchalik.com/wxforecast.php
Setting.php:
// use "Zone|Location|Point-printableURL",  as entries .. first one will be the default forecast.
"NJZ008|Pompton Plains|https://forecast.weather.gov/MapClick.php?textField1=40.97&textField2=-74.3#.W3a1UuhKg-U",
"NJZ020|Lavalette|https://forecast.weather.gov/MapClick.php?lat=39.9685&lon=-74.0692#.W3a2BuhKg-U",
"NJZ003|Wallington|https://forecast.weather.gov/MapClick.php?lat=40.8524&lon=-74.116#.W3a4EuhKg-U",
"NJZ001|Mountain Creek|https://forecast.weather.gov/MapClick.php?lat=41.1917&lon=-74.5045#.W3a4dOhKg-U",
« Reply #6 on: August 17, 2018, 10:03:19 AM »
Setting.php:
Your forecast is working now.
Offline richpuch
« Reply #7 on: August 17, 2018, 10:33:41 AM »
Thanks...its working now.
Offline richpuch
« Reply #8 on: August 22, 2018, 06:26:40 AM »
Ken,
Its happening again and it went back to 7/31 as last update.  How did you fix it last time?  is there something on my end making it go back to 7/31?
Rich
