Hi all,
I've been contemplating buying a weather station for a little while now and been reading through the forums here and learning what I can. Now that I've narrowed down my choices I could do with a little help on where to position the station and how to connect everything given my site is a little awkward.
I live on a farm and our house is an old building with 2' thick walls. This means that wifi doesn't really make it outside the house. the house is also surrounded by trees and hedges so a station mounted above the roof is still going to be quite sheltered. Also, both chimneys are in full time use over the winter as we heat the house with wood.
I think the best option is to mount a 20' pole on the corner of one of the barns which, while there are some smaller trees around them, the hedges were recently laid so won't be high in the next few years and also have an open field around them. The back of one of the barns also houses my workshop which has a wifi access point in it.
I've attached a few photos to show the area around the house and the barns with a yellow line showing what I think is the best place to attach a 20' pole. This would put the station about 10' above the roof and 10' from the chimney. The stove connected to the chimney is from the wood burner in the workshop and is only used when I'm spending a full day in there during cold weather so isn't in regular use.
There's nowhere else other than the house that has internet connectivity so it needs to be close to the barn. Now, equipment wise, I'm thinking of getting the Froggit DP1500 (Ecowitt g1001 equivalent) although the separated sensor package of the g1002 also looks interesting.
https://www.froggit.de/product_info.php?info=p444_dp1500-wi-fi-weather-server-usb-dongle-incl--1-x-dp50---wh4000se-all-in-one-outdoor-sensor.html)
as there's no point me having a display when it's going to be in the workshop/barn. However, that means that the indoor temperature and humidity that the g1000 box measures wouldn't be the inside house measurement so that's pretty redundant. Also, while the corrugated tin on the side/roof of the barn should pass the sensor signal from the station that's only 10-15' away, there's probably no chance of getting a signal if I put a couple of soil sensors in the allotment 100m away.
the Froggit unit also comes with the DP50, which is another temp/humidity sensor. I'm not quite sure where that would normally be placed if there's also similar sensors in both the g1000 box for indoors and the wh4000 main station unit. Can anyone shed light on that?
My other thought was to mount the G1000 in a plastic box on the outside of the barn to give better reception to the station and possibly some other sensors on the 868 MHz band that might reach to our allotment but then the temp/humidity would be useless. I would like air quality meter and lightning detector add ons at some point though. The wifi from inside the workshop should reach through to the g1000 in a plastic box outside.
any thoughts suggestions would be most welcome.
view of house with surrounding trees, taken from corner of the allotment, you can see the barn in the background behind the trees.
View across field to barns behind hedge
closer view with yellow line showing proposed site of pole
close up of corner of barn with proposed pole position, I can bolt all the way through into the corner post of the barn for a really solid attachment as it does get quite windy here in Devon in the winter.
Front view of barns with post site highlighted
althernative view with chimney visible.
