I've had some luck in fixing a few things for the next update (version 6.08). I found a fix for the date formatting problems with the All time high and low section. It also apprears that Brian has changed the format that some of the sunrise, sunset, etc readings are now passed to test tags. I have made a change to allow that to display correctly.
I am testing the changes now, especially the wetbulb updating of the snow/rain icon. Once we get above freezing around here, maybe I can see if it works! I'll let everyone here know when I have this next version released.
Question: Is anyone else using WD version 37Q Build 28 or later and noticing the times screwed up in the Almanac section?
Scott
