Problems with the forum? Please use Contact or PM saratogaWX with details. Thanks!
AcuRite does have a temp/humidity sensor replacement for the newer 5-N-1 models.https://www.acurite.com/temperature-and-humidity-sensor-replacement-for-5-in-1-weather-sensors.html
Did you try doing a reset of your five and one removing the batteries sometimes when batteries go low it messes with the temperature reading.
Quote from: worachj on November 03, 2018, 08:07:39 AMAcuRite does have a temp/humidity sensor replacement for the newer 5-N-1 models.https://www.acurite.com/temperature-and-humidity-sensor-replacement-for-5-in-1-weather-sensors.htmlThanks, does the actual sensor chip have a hole in it's plastic case that allows for sampling the temp and humidity? Is there anything under that IC's sampling hole that can become contaminated/corroded from a salt air environment?Can it be cleaned out with a contact cleaner?QuoteDid you try doing a reset of your five and one removing the batteries sometimes when batteries go low it messes with the temperature reading.Thanks, that's good to know. I didn't know low batteries would make the readings go whacky.
I was just going to ask George if you've heard of anybody cleaning the board.
So what's in an electronic contact cleaner? Typically a blend of several volatile solvents, and maybe a lubricant. No way I'd let that get into a T&H sensor.
George, regarding contact lens cleaners, they appear to be mostly water with some salts or organic salt-like compounds. My view: keep 'em away from your sensor!
