Author Topic: 24 Hour Day Graphs Not Available On wxhistory.php  (Read 1415 times)
« on: January 04, 2013, 01:57:13 AM »
I'm not the only one with a problem on this page.  At http://stillwaterweather.com/wx/wxhistory.php at the bottom of each day it reads: "24 Hour Graph of this day is not available (20121201.gif)".  This is so even though the dated graph gif referred to is in my wx folder.  How do I make it available?
Offline gwwilk
  • Southeast Lincoln Weather
Re: 24 Hour Day Graphs Not Available On wxhistory.php
« Reply #1 on: January 04, 2013, 07:37:46 AM »
Mine are showing up.  Ergo, it's a path/configuration issue if the graphs are somewhere on your site?
Regards, Jerry Wilkins
gwwilk@gmail.com
Offline ALITTLEweird1
  • Mark
    • North Bend Weather
« Reply #2 on: January 04, 2013, 06:47:46 PM »
As Jerry said, it must be a path issue cause the graph is there..
http://stillwaterweather.com/wx/20121201.gif
Software: WeatherDisplay
« Reply #3 on: January 05, 2013, 02:34:27 PM »
This problem finally solved.  First, I had no luck reworking paths.  So I tried replacing wxhistory.php with an older version and that fixed it.
