Author Topic: Add image in Version 4.20 of the alt dashboard by WebsterWeatherLIVE.com  (Read 3556 times)
Offline Axelvold
I have some free space in my dashboard and now I want to put a image from my ip cam there, but where in the source code would I have to put the code?
I think it should be after this code, but I'm not really sure.
<span class="ajax" id="ajaxconditionicon2">
  <img src="<?php echo $imagesDir newIcon($iconnumber?>"
alt="<?php $t1 fixupCondition($Currentsolardescription);
  echo $t1?>
  title="<?php echo $t1?>" height="108" width="112" />
  </span>
      </td>
  </tr>
  <tr>
              <td align="center" colspan="2" class="data1" style="text-align: center;border: none">
  <span class="ajax" id="ajaxcurrentcond"><?php//ajaxweatherreport?>
  <?php echo $t1?> </span><br/><br/>
  <strong><span class="ajax" id="ajaxtemp" style="font-size:30px">
          <?php echo strip_units($temperature) . $uomTemp?>
          </span></strong>
          <span class="ajax" id="ajaxtemparrow"><?php echo gen_difference(
          $temperaturestrip_units($temperature) -strip_units($tempchangehour), '',
          'Warmer %s'.$uomTemp.' than last hour.',
          'Colder %s'.$uomTemp.' than last hour.');?>
</span><br/>
                          <span class="ajax" id="ajaxheatcolorword"><?php  echo $heatcolourword?></span><br/>
        </td>
  </tr>
                  <tr align="center">
                      <td align="center" valign="top" class="data1" style="text-align: center;border: none">
            <span class="ajax" id="ajaxthermometer">
                          <?php $tstr "Currently $temperature, Max: $maxtemp, Min: $mintemp"?>
                          <img src="thermometer.php?t=<?php echo strip_units($temperature); ?>" alt="<?php echo $tstr?>"
          title="<?php echo $tstr?>" height="170" width="54" /> </span>
      </td>
                      <td class="data1" style="text-align: center;border: none" valign="middle">
                          Feels like:<br/><span class="ajax" id="ajaxfeelslike">
  <?php echo strip_units($feelslike) . $uomTemp?>
  </span><br/><br/>
                          24-hr<br/>difference<br/>
                          <?php
  echo gen_difference($temperature$temp24hoursago$uomTemp,
     'Warmer %s'.$uomTemp.' than yesterday at this time.',
  'Colder %s'.$uomTemp.' than yesterday at this time.'); ?>
                      </td>
                 </tr>
             <tr>
             <td colspan="2">
<table width="100%"  class="data1" style="font-size: 9px;border: none">
                    <tr>
                      <th style="text-align: left;">LOCALLY:</th>
                      <th style="text-align: center;">Today</th>
                      <th style="text-align: center;">Yesterday</th>
                    </tr>
                    <tr>
                      <td><strong>High:</strong></td>
                      <td style="font-size: 9px;text-align: center;">
  <span class="ajax" id="ajaxtempmax">
                          <?php echo strip_units($maxtemp) . $uomTemp?></span><br/>
                          <?php echo fixup_time($maxtempt); ?>
      </td>
                          <?php echo strip_units($maxtempyest) . $uomTemp?><br/>
                          <?php echo fixup_time($maxtempyestt); ?>
      </td>
                    </tr>
                    <tr>
                      <td class="data1" style="font-size: 9px;"><strong>Low:</strong></td>
                      <td class="data1" style="font-size: 9px;text-align: center;">
  <span class="ajax" id="ajaxtempmin">
                          <?php echo strip_units($mintemp) . $uomTemp?></span><br/>
                          <?php echo fixup_time($mintempt); ?>
      </td>
  <?php echo strip_units($mintempyest) . $uomTemp?><br/>
                          <?php echo fixup_time($mintempyestt); ?>
        </td>
                    </tr>
Lars Magnusson
Axelvold / Sweden
55° 57' 41" N / 13° 6' 1" E
Offline jgillett
  • Boltek, Win7 Pro, ToA
    • TiggrWeather Phoenix
I would suggest getting current with the alt dashboard first. You are way behind, and Scott has added a number of fixes between your 4.20 and the current 6.51.
W7JKG
Offline Axelvold
I know that, but most of the new things could I not use because that there no one that provides the data for free in Sweden.
That's why I still use version 4.20
Lars Magnusson
Axelvold / Sweden
Offline MesquiteWx
    • Mesquite Weather
Hi Axelvold, if you could display a wider view of what's above it and some more code that would be helpful. Doesn't look like the code you posted is for that section of the dashboard.
Offline Axelvold
The code I did post is what generates the temperatur, and I want to have the picture under that.
      </td>
        </td>
                    </tr>
<?php
if ($useWU) {  //  Show Weather Underground Record HIGH/LOW data
                    <tr>
Lars Magnusson
Axelvold / Sweden
Offline Dr Obbins
I think you are close. Please post the code you have plus the next 15 lines.
Offline Axelvold
ok, here is some more code.
  echo $t1?>
  </span>
      </td>
  </tr>
  <tr>
          </span></strong>
</span><br/>
        </td>
  </tr>
                  <tr align="center">
      </td>
  </span><br/><br/>
                          <?php
                      </td>
                 </tr>
             <tr>
             <td colspan="2">
                    <tr>
                    </tr>
                    <tr>
      </td>
      </td>
                    </tr>
                    <tr>
      </td>
        </td>
                    </tr>
<?php
                    <tr>
                      <td><strong>NWS<br/>Normal:<br/>Record:<br/>Year:</strong></td>
                      <td style="text-align: center;">
                          <b>HIGH</b><br/>
                          <?php echo strip_units($WUmaxtemp) . $uomTemp?><br/>
                          <?php echo strip_units($WUmaxtempr) . $uomTemp?><br/>
                          <?php echo $WUmaxtempryr?><br/>
              </td>
                          <b>LOW</b><br/>
                          <?php echo strip_units($WUmintemp) . $uomTemp?><br/>
                          <?php echo strip_units($WUmintempr) . $uomTemp?><br/>
                          <?php echo $WUmintempryr?><br/>
              </td>
                    </tr>
<?php // end $useWU  ---------------------------------------- ?>
Lars Magnusson
Axelvold / Sweden
Offline Dr Obbins
I usually make modifications with a bit of trial and error.  ;) See what this will do for you.
                    <tr>
                    </tr>
                    <tr>
      </td>
      </td>
                    </tr>
                    <tr>
      </td>
        </td>
                    </tr>
                    <tr>
          <td>
    <img width="100" height="100" border="0" src="your webcam.jpg" alt="" />
         </td>
                    </tr>
  <?php
                    <tr>
                          <b>HIGH</b><br/>
              </td>
                          <b>LOW</b><br/>
              </td>
                    </tr>
Offline Axelvold
It's a small step, but the column gets to wide.
Lars Magnusson
Axelvold / Sweden
Offline Axelvold
Got it working, with this.
<tr>
                      <td class="data1" colspan="3"><center><b>Latest image IP cam:<img width="160" height="120" border="0" src="your webcam.jpg" alt="" /></b></center></td>
                    </tr>
Lars Magnusson
Axelvold / Sweden
Offline Dr Obbins
Re: Add image in Version 4.20 of the alt dashboard by WebsterWeatherLIVE.com
« Reply #10 on: December 27, 2011, 03:45:29 PM »
Glad to see you got it worked out.
Offline Axelvold
« Reply #11 on: December 27, 2011, 04:15:16 PM »
Thank's for your help.
Lars Magnusson
Axelvold / Sweden
