Weather Station Hardware > Davis Instruments Weather Stations
Lithium ion supercap to replace original supercap
miraculon:
I found some intriguing YouTube videos regarding Lithium ion supercaps. (AKA hybrid)
After having a second supercap failure, these sound interesting. Has anyone experimented with these? I am considering replacing the supercap in one of my SIM transmitters.
miraculon:
I ordered some 30F 3.8V VMF306M3R8 supercaps from Mouser to experiment with.
They are CDE (Cornell Dublier) Ultracapacitors, Lithium Ion type. I'll report my results after I install them. It will be a "worked, didn't work" report, nothing comprehensive.
miraculon:
I changed the cap this morning to the "ultracap". It went the same as other supercap remove/replace instances.
The caps arrived with about 3.2V charge (all 5 caps). They say not to let the leads short, so I was careful of that. The precharge is similar to the lithium CR123A when it is fully charged.
The station is reporting data again and is working. Hopefully, the charging/discharge will be OK. I suspect that I'll see a longer run time on the cap since it is 30F and the original is 10F.
It was an unremarkable, routine exercise. If anything unusual develops, I'll post it here.
DaleReid:
Greg,
Thanks for the background, the install and if any problems (even if none) a future post to ahem re-cap your experiences.
Hope all is running well and you're enjoying the great summer like weather in late spring. At least over here in EC. Dale
rv1cj:
We need an opinion if the solar panel can charge 30 F.
[#] Next page
