Weather Station Hardware > Weather Web Cams
IPTimelapse Weather Display Update
sebeclake:
Hi, there is a thumbnail option on the Exposure tab page. You can set the size of the thumbnail image. Is that what you need?
-Mike
weatherdoc:
My videos are 1280x720 (https://novawx.dscloud.me/wxcam-lapse.php). I set the width in the Encoding section of the TIMELAPSE tab to 1280. I also cropped the view in the Crop tab to show a smaller area because I wanted to minimize any views of my neighbor's yards in the video.
weatherdoc:
You can change the time format on the Schedule & FTP tab on the left side under General Options just to the right/under Image Text.
weatheroz:
--- Quote from: sebeclake on February 08, 2023, 01:30:00 PM ---Hi, there is a thumbnail option on the Exposure tab page. You can set the size of the thumbnail image. Is that what you need?
--- End quote ---
Thanks for that, sorted that one out now. :)
What I would like to be able to do is to do similar what I'm doing in a roundabout way with the ancient ImageSalsa software, that's creating a 'box' to display my local data, and also hide my neighbours back door area.
Here's a clip of what I'm after. :-
https://jimboombaweather.com/cam/20230213100009.jpg
This is how I want to be able to display it.
https://jimboombaweather.com/cam/230213100030.jpg
Whilst I can currently get ImageSalsa to load the thumbnail and add that stuff, I'm guessing that ImageSalsa will eventually stop working with some windows update, as the developer left it over 15 years ago.
weatherdoc:
You should be able to create a box with IPTimelapse for your local data. You're already displaying the data at the top of your image with a semi-transparent background. I think you can do so via the Stream Text tab and Weather Text section. You can play with the x and y position to create a box of the appropriate size/location and then change the transparency and box color to cover your neighbor's house.
[#] Next page
[*] Previous page
