My Meteobridge is connected to a VP2 and has worked perfectly since July up until yesterday. Now it will only display current data for 5 minutes after being rebooted from the System page. The messgae on the System page is below.
Any ideas ?
www.pilor.com wnetd (16.11.2016 08:24:07): process started.
system (16.11.2016 08:24:07): start of logging process initiated.
logger (16.11.2016 08:24:08): Historical data loaded (19 records).
logger (16.11.2016 08:24:08): data logger (version 5.0s, build 10732) started.
logger (16.11.2016 08:24:09): connect station 0 (Vantage via USB serial).
logger (16.11.2016 08:24:10): wakeup sent.
logger (16.11.2016 08:24:10): internal logger activated.
logger (16.11.2016 08:24:10): syncing.
logger (16.11.2016 08:24:20): gettime request sent.
logger (16.11.2016 08:24:20): no Vantage time offset.
logger (16.11.2016 08:24:20): eeprom request sent.
logger (16.11.2016 08:24:20): rain collector size 0.2 mm per tick.
logger (16.11.2016 08:24:20): transmitter 1 active as station type (#0) "ISS".
logger (16.11.2016 08:24:20): firmware version request sent.
logger (16.11.2016 08:24:20): firmware version 3.12
logger (16.11.2016 08:24:20): no reading of Vantage's internal logger.
logger (16.11.2016 08:29:48): unexpected 0 bytes.
logger (16.11.2016 08:29:48): station 0 (Vantage), can't set attributes of device /dev/ttyMH to former values: Input/output error
logger (16.11.2016 08:29:48): disconnect station 0 (Vantage): response without data
logger (16.11.2016 08:30:18): station 0 (Vantage), can't open device /dev/ttyMH: No such file or directory
logger (16.11.2016 08:30:48): station 0 (Vantage), can't open device /dev/ttyMH: No such file or directory
