1) Atlas display with Wifi. App access to live weather data over local network/no internet required, switch to remote internet data when out of range.
2) Local Forecast. Radar image. Touch animated forecast/forecast icon to show "Extended Forecast" and "Radar" menu screen. Button to show time lapse radar.
3) Sell temp/humidity sensors with integrated lcd display. Transmit sensor data to Atlas display. Show temp/humidity readings on ticker at bottom of the Atlas display. Allow users to assign custom names. Left/Right arrows to switch among sensors. Auto cycle setting.
78F indoor 49% -> 74F bedroom 47% -> 20F freezer 87% -> 95F gHouse 43%
4) On Calendar, display rainfall indicator above days that had rainfall. Touch date to show daily data. Retrieve daily data from SD card.
5) Menu setting for Automatic/Manual over-the-air firmware updates. Memory chip with backup firmware to protect against corrupt updates or power outage.
6) Page curl in top corner or left/right arrows that would allow a user to switch between full animated forecast or sensors(soil sensor, air quality, sunrise/sunset times, etc) readings and forecast icon in bottom right corner of forecast section.
7) Menu setting to show/hide rain gauge to the right of the rain info.
8 ) 1 second wind speed sample rate. Dynamic transmit rate based on weather conditions. Wind speed changing quickly = faster transmit speed. Calm day = slower transmit speed, which would conserve battery power.
9) Transmit fan speed with temp/humidity data. Slower fan speed or fan not working = less accurate temperature/humidity.
10) Add IFTTT(If this, then that) to the display. Sell smart switches that can communicate with the Atlas display or through the local wifi network. Low soil moisture = turn on water irrigation pump/sprinkler system or rain barrel valve.
11) Midnight to midnight rainfall option.
12) Enable/Disable selected ticker messages. Adjustable scroll speed.
13) Chill hours ticker message. Useful for gardeners and fruit tree growers.
https://en.wikipedia.org/wiki/Chilling_requirement.
14) Battery backup. Low power mode during power outage that would allow the display to receive sensor data. Turn off display after x seconds to conserve battery power.
15) Light/Dark mode.
16) Ability to turn on/off backlight.
17) Add a "Last Rain x Days Ago" message.
18) Add "24 hours" and "12 hours" on the graph screen.
19) "Yesterday's Rainfall" ticker message.
20) At the bottom of the lightning detector graph screen, put "Closest --mi Last --mi Strikes --".
21) On the left side of the lightning detector graph screen, put a "Strikes" button and a "Distance" button. Pressing the Strikes button would show a graph of the number of lightning strikes. Pressing the Distance button would show a graph of the lightning strike distances.
22) At the top right corner of the Yesterday/Today Record screen, put a "Page 2" button. Pressing the button, would show readings for pressure, light intensity, lightning distance. On that screen the button would change to "Page 1".
23) If the Atlas display had wifi, lightning data could be uploaded and compared to lightning data from other Atlas users in a x mile radius. Lightning data from at least three users in the same area would be needed to triangulate the location of the lightning strike.
24) Atlas replacement parts.
25) Add an external antenna port to the Altas sensor. A wire could be connected to the external antenna port and then connected to a metal mounting pole. The metal pole would become an antenna. Or a long wire could be connected to the external antenna port and then hung down to the bottom of the mounting pole or the wire could be placed in the attic. Some people have a house with a metal roof. The metal roof blocks the signal from the sensor. An external antenna would allow the signal to be transmitted below the metal roof.
26) If interference is detected during a storm(wind speed increasing, rainfall detected), assume the interference is lightning. Sometimes my Atlas display shows "interference detected" during a storm when there is lightning flashes and thunder, but on a clear day, it does NOT show interference detected. Maybe there could be a sensitivity setting on the display.
27) Add "Feels Like" to the "Dew Point", "Heat index", and "Wind Chill" ticker section.
On the Atlas "Yesterday's Records" screen, if there was no lightning, it shows "---- total" for lightning activity. It should show "0 total".
