Weather Software => WeeWX Software => Topic started by: distortionist on October 23, 2020, 09:41:33 AM
It seems it is not reading it and storing it for some reason, the sensor works on the WS-2000 console, and its being reported to all the places the consoles themselves report to. I am sure I just need to adjust something somewhere but what and where? I noticed people have had issues when the driver was new, but it also seems to have been fixed along with a rain issue from what I am reading. I don't notice any rain problems so I am not sure it is the same issue.
OK
I fixed it after hours of trying to figure it out. I don't know where these things are defined but I was able to edit the install py and find the errors, fix them, re tar.gz it, and install it.
So... Now problem 2, I have not spent the same hours in this, but I will, unless someone helps me out with an answer, but it is showing my radation in w/m2 and I need it in Lux.
Off I go digging through google for hours again.
The better forum section to post this would be the weewx software area. Hopefully, an admin will come by and move the conversation for you.
Also, while you'll get some support for weewx here on WXForum, the authoritative place for weewx questions would be on their support forum:
https://groups.google.com/forum/#!forum/weewx-user (https://groups.google.com/forum/#!forum/weewx-user)
Hope you find a resolution to your issue soon!
OK
once you understand that the GW1000 doesn't receive what weewx understands as radiation, things become clearer
the only thing you need to fix is getting the proper data into the field named radiation (1st step). 2nd step will be to deal with the units.
1. regarding radiation - the WH65/WS80/WS68 sensor arrays don't provide real radiation but luminosity in Lux. The consoles convert it into radiation.
If you want to have W/m2 you need to put the following line into the
[StdCalibrate] [[Corrections]] stanza of your weewx.conf
[[StdCalibrate]
[[Corrections]]
# For each type, an arbitrary calibration expression can be given.
# It should be in the units defined in the StdConvert section.
# Example:
radiation = luminosity/126.7 if luminosity is not None else None
# radiation comes with the unit watt_per_meter_squared (W/m2)
2. If you want to have the radiation in Lux, you will also have to "reconfigure" the units for radiation
a) the entry in the [StdCalibrate] [[Corrections]] stanza of your weewx.conf would be
because you want to display radiation in your skin (screen, user interface).
and
b) in the file /usr/share/weewx/user/extensions.py (path depending on installation method) you will have to make an entry
import weewx.units
weewx.units.obs_group_dict['radiation'] = 'group_illuminance'
because "Lux" is the unit belonging to the unit group illuminance.
That should do the job.
save - and restart weewx
it's - by the way - (almost) everything documented in the WiKi - but it's a lot of stuff to read and you need some time to get the full(er) picture :roll:
After going through the effort to add radiation to my weewx, and the graphs for it, I found that the only difference between the graphs was 1) the vertical axis is UVx100 for the radiation Y-Axis, and 2) the radiation graph has nice smooth lines.
... Not worth the effort, IMO.
showing radiation is pre-configured in the Seasons skin (as long as the variable has a value assigned: no value - no picture) - however you can change it (axis, length, etc) in skin.conf if you are not happy with the "standard".
You don't need to add it - just feed the radiation variable with the luminosity value as described above (whether W/m2 or Lux is your choice) - everything else goes by itself.
However, I don't know what you were all doing in the first place - what you call " the effort to add radiation to my weewx, and the graphs for it", because it's basically just this one line to add at the right place (as shown above). Or, if you want to have it shown in Lux, two more lines in extensions.py.
Maybe you did much more not knowing how simple it could be.
As I have no information about it except the vague " effort to add radiation to my weewx, and the graphs for it", I cannot say more.
And as the difference in the result of either luminosity in Lux or in W/m2 is just a proportionality factor, the graphs would look the same - and the Cheetah graph generator would draw it also proportionally. In fact, apart from the numbers at the scale they should look pretty much the same.
Yes, adding the line to stdcalibrate->corrections and making the change in extensions.py is simple, and takes only a minute or two to do.
The radiation graph was not simple. I had to modify template / include files, based on instructions I found on the weewx user group. That was not worth the effort -> same graph, same Y-axis, same numbers x100, and about an hour of my time trying to figure out the instructions, how it works, etc. Of course, one doesn't find out these things unless they try. I posted the graphs to help someone else determine whether it is worth their time.
Just my $0.2 worth. Please don't take it personally.
not sure what you found there - as it is not necessary - it's already all there (except for radiation) ... :roll:
Of course, if you wanted to add a completely new sensor, e.g. some extraTemperature or so, then you have to go down the road from skin.conf, index.html.tmpl, current.inc and hilo.inc (if you also want to see them in the left pane).
But for the standard stuff like indoor/outdoor Temp/Humidity, wind, radiation, rain ..., it's already done.
If you don't do anything, you see all the standard values and graphs (except for the radiation - that needs this extra line).
But, that way, you learned what to do when you want to add more non-standard sensors. ;) :-) - so it may still have been worth it. 8-)
And - no offense taken. :-) ;)
But, that way, you leanred what to do when you want to add more non-standard sensors. ;) :-) - so it may still have bee worth it. 8-)
Aye, that I did [tup] -- way more than I wanted to know about weewx :lol:
Kidding aside, weewx is great software: well written, meticulously documented, knowledgeable and patient support group, and highly customizable. I use it exclusively. Just wanted to make it clear that just because I gripe about it from time to time, I still hold it in high regard.
