Author Topic: COM port issue with Envoy8X and USB data logger  (Read 2369 times)
Offline Dr P
« on: July 16, 2013, 09:19:29 PM »
Hello,
I have been trying to configure my ISSs with an Envoy8X through WTDU but never could get it to work.
When I open WTDU I get an error message : "No COM port found on this computer. Did you install a virtual COM port driver ?"  And then when I try to set the communication port, none appears in the "COM" window. When I looked into WTDU help, they say to check that the drivers are installed: I found these two SiLib.sys and SiUSBXp.sys
Do I need another driver ?
I have been trying to find virtual COM port driver for Davis instruments online, and found one on this page http://www.silabs.com/products/mcu/Pages/USBtoUARTBridgeVCPDrivers.aspx   but I could not install it, because "the device driver installation wizard was unable to find any drivers designed for your machine".
Has anyone an idea about what else I can do ?
This is an urgent matter and Davis support is apparently too busy these days to answer my emails and I cannot call them as I am in the Philippines with no possibility to give international calls, so I really hope someone here can help me !
Re: COM port issue with Envoy8X and USB data logger
« Reply #1 on: July 16, 2013, 10:34:17 PM »
If I remember correctly, there is a utility in a sub-folder of the drivers called CP210X USB to Serial Converter.exe that will fix this issue.
Check the  \WeatherDTU\Drivers\Utilities folder.
Offline Dr P
« Reply #2 on: July 16, 2013, 11:47:43 PM »
It worked, thank you so much for this quick answer !
I cannot believe that they would not mention that in the help section.
Offline Weather Display
« Reply #3 on: July 17, 2013, 03:44:48 PM »
the USB data logger defaults to that mode
until you select to use USB instead of serial in weatherlink software
Brian
info@weather-display.com
