Author Topic: Weatherlink.com 2.0 Summary replacement script  (Read 7950 times)
Offline livefeed
    • Lusby Live!
Re: Weatherlink.com 2.0 Summary replacement script
« Reply #50 on: January 19, 2019, 01:43:25 PM »
Excellent script, thank you for coding this. Only issue I am having is with one of my extra sensors not display the temp correctly, any ideas?
Any way to change the name of the sensors?
Offline wvdkuil
  • Wim van der kuil
« Reply #51 on: January 19, 2019, 02:06:07 PM »
I can only look at it if i have the URL of the page.
I have to check if it is in the data or in the script
Wim
Offline livefeed
    • Lusby Live!
Offline wvdkuil
  • Wim van der kuil
« Reply #53 on: January 19, 2019, 04:12:40 PM »
opps sorry;
http://www.nitram-media.com/weather/wl2/load_wl2.php
The loaded data http://www.nitram-media.com/weather/wl2/cache/001D0AE057D9.xml
has soil-moist 1,2,3,4  and temp-soil 2,3
Your settings in http://www.nitram-media.com/weather/wl2/load_wl2.php  have
$wl_is_t_soil1  = true;        // soil temp sensors 1 set to true or false
$wl_is_t_soil2  = true;        // add more lines if you have more then 2, max = 4
$wl_is_m_soil1  = true;        // soil moisture sensors 1 set to true or false
$wl_is_m_soil2  = true;        // add more lines if you have more then 2, max = 4
If you only have soil sensors 2 and 3  you should change that to
$wl_is_t_soil1  = false;        // soil temp sensors 1 set to true or false
$wl_is_t_soil3  = true;        // add more lines if you have more then 2, max = 4
$wl_is_m_soil1  = false;        // soil moisture sensors 1 set to true or false
$wl_is_m_soil3  = true;
Wim
Offline casacota
    • Observatori de Sant Martí de Canals
« Reply #54 on: January 22, 2019, 08:30:50 PM »
Added the first "official" version of the two scripts.
One for the summary page, one for the "blue" page.
Check the first post for the download.
Summary demo: www.weerstation-herent.be/wl2/load_wl2.php
Blue clouds demo: www.weerstation-herent.be/wl2/load_wl2-blue.php
For this demo I "upped" the cache time from 5 minutes to 15 minutes.  Less loads for the Davis server.
Wim
Great, thanks. If you need it... background attached. Looks like that: http://casacota.dynalias.com/weatherlink/wlblau.htm
Offline Mchd17
« Reply #55 on: January 28, 2019, 06:59:46 PM »
Summary page, which you can share, is under Share & Uploads within WeatherLink 2.0
I am sure someone else has posted about it, but just found it myself
Offline zmarfak
    • Matar
« Reply #56 on: June 01, 2020, 02:33:51 AM »
Just some information if you want to integrate the "load_wl2.php" as an include.
because I'm changing some webpages, I decided to integrate "load_wl2.php" in a page and not to use the standalone version anymore.
Because I try no to use the HTML <iframe> tag, I decided to use the PHP "include"  statement.
First thing I did is :
$wl_standalone  = false;   //  true = include enclosing html head
                                           //  false= only the div and table
Then a in my "wxwl2.php" page :
<div id="main-copy">
<br/>
<?php
include("load_wl2.php");
</div><!-- end main-copy -->
<?php
include("footer.php");
Result was a html page that stopped after the "load_wl2.php" script, my "footer.php" was not executed
After some "research" I found in "load_wl2.php" line 498 -501 :
if (!isset ($wl_standalone) || $wl_standalone == true) {
echo '</body>
</html>'.PHP_EOL;}
exit;
I changed this to the code hereunder, in that case the "exit" statement would only be executed for the "non standalone"
echo '</body>
</html>'.PHP_EOL; exit;}
Now it's ok, I hope this is the correct way to do it otherwise let me know please.
Patrick
Davis Vantage Pro2 with a Meteobridge NANO SD and WL (6.04) on a Intel NUC
https://www.matar.be
Offline kokos1405
« Reply #57 on: September 01, 2020, 06:06:52 AM »
Any support for weatherlink live versions?
Offline wvdkuil
  • Wim van der kuil
« Reply #58 on: September 01, 2020, 06:17:31 AM »
The data used is available on wl.comv1API, so all "old" WLIP and weatherlink.exe uploads can use this script.
But not with  WL .comv2API  as there are no high-lows in the data=> https://weatherlink.github.io/v2-api/
And WeatherLinkLive is only accessible using WL.comv2API
There is a bulletin  from weatherlink .com which can be included on your website.
Wim
