Author Topic: managing Ecowitt IoT devices in Home Assistant  (Read 548 times)
Offline Gyvate
« on: May 21, 2025, 01:38:45 PM »
there is now a still experimental integration for Ecowitt IoT devices (ecowitt_iot), independent of the read-only Ecowitt integration, available via HACS (Home Assistant Community Store).
see WiKi:
https://meshka.eu/Ecowitt/dokuwiki/doku.php?id=dataloggers#ha-ecowitt-iot
the progress will be documented there.
EDIT: updated link due to WiKi reorganization
« Last Edit: May 25, 2025, 05:58:57 AM by Gyvate »
WS2350 1.7.0,GW1000 1.7.7,WH2650 WiFi 1.7.7,GW1100 2.3.7,GW1200 1.3.4,GW2000 3.2.1,GW3000 1.0.3,HP2550 2.0.1,5.1.9; HP3500 1.7.2,WS3800 1.3.4, WS3910 1.3.4, WN1910 1.2.4,WN1820/WN1980 1.3.5;
Ecowitt WS90, WS85, WS80, WS68, WS69, WN30, WH31,WH31-EP, WH32,WH32-EP, WH32B/WN32P, WN34D,L,S,  WN35,WH40, WH41[PM2.5], WH45, WH46D, WH51, WH55, WH57, LDS01
Blake-Larsen Sun Recorder - RPi4/weewx 4.10.2/CumulusMX 4063/MeteobridgePro 6.1,Meteobridge RPi4B-2GB,MB VM
Barani Meteoshield Pro,MetSpecRad02,SMarTCELLino;Dracal BAR20
WIKI https://meshka.eu/Ecowitt/dokuwiki
Offline Wooks61
  • Aerospace Engineer Avionics (Ret.)
Re: managing Ecowitt IoT devices in Home Assistant
« Reply #1 on: May 24, 2025, 08:24:10 PM »
see WiKi:
https://meshka.eu/Ecowitt/dokuwiki/doku.php?id=start#ha-ecowitt-iot
Has the link changed?  It seems to open at the Start of the Wiki  :?:
Maybe https://meshka.eu/Ecowitt/dokuwiki/doku.php?id=dataloggers#homeassistant would be better  :?:
Offline Gyvate
« Reply #2 on: May 25, 2025, 05:58:20 AM »
did some WiKi housekeeping and segmentation yesterday - the link has changed - and I've corrected it now ... - thanks for the hint  [tup]
