Author Topic: warning: New release of firmware v3.2.2 for the GW2000  (Read 341 times)
Offline olicat
  • GWxx00, HPx5x1C, WN19xxC & WS3xx0C
    • FOSHKplugin
« on: May 20, 2025, 06:09:48 AM »
Hi!
Apparently Ecowitt has accidentally re-released version v3.2.2 for the GW2000, although we were already using version v3.2.4.
The changelog is identical to the version 3.2.2 released at that time:
  • Supports the LDS01 data filter level algorithm
  • Supports custom ecowitt protocol mqtt upload
  • Supports relative air pressure algorithm based on altitude
  • Supports VPD webpage display and upload, IoT smart control
This means that all fixes that already came with v3.2.4 (such as bugfix socket closure) are missing.
I strongly advise against this downgrade as long as Ecowitt does not explicitly point this out.
Regards, Oliver
Offline Gyvate
Re: warning: New release of firmware v3.2.2 for the GW2000
« Reply #1 on: May 20, 2025, 10:21:15 AM »
looks like the mistake was noticed - in my WebUi an upgrade to 3.2.4 is offered
changelog
Version 3.2.5 is under testing
New version:V3.2.5
-Optimize TCP reception.
-Optimizes the RF IoT Network.
« Last Edit: May 20, 2025, 10:25:05 AM by Gyvate »
WS2350 1.7.0,GW1000 1.7.7,WH2650 WiFi 1.7.7,GW1100 2.3.7,GW1200 1.3.4,GW2000 3.2.1,GW3000 1.0.3,HP2550 2.0.1,5.1.9; HP3500 1.7.2,WS3800 1.3.4, WS3910 1.3.4, WN1910 1.2.4,WN1820/WN1980 1.3.5;
Ecowitt WS90, WS85, WS80, WS68, WS69, WN30, WH31,WH31-EP, WH32,WH32-EP, WH32B/WN32P, WN34D,L,S,  WN35,WH40, WH41[PM2.5], WH45, WH46D, WH51, WH55, WH57, LDS01
Blake-Larsen Sun Recorder - RPi4/weewx 4.10.2/CumulusMX 4063/MeteobridgePro 6.1,Meteobridge RPi4B-2GB,MB VM
Barani Meteoshield Pro,MetSpecRad02,SMarTCELLino;Dracal BAR20
WIKI https://meshka.eu/Ecowitt/dokuwiki
