Author Topic: new Meteobridge Aurora Cloud dashboard  (Read 3710 times)
Offline davidmc36
  • FN25IE61IX
    • MorewoodW34
Re: new Meteobridge Aurora Cloud dashboard
« Reply #25 on: May 31, 2025, 12:04:06 PM »
I choose image WITHOUT annotation but it has this covering my time stamp.
Offline Gyvate
« Reply #26 on: May 31, 2025, 03:08:11 PM »
So we upload all historical data available, back to 2020.
But on the dashboard, only the current year is available to view in charts.
Is it possible to have charts viewable from previous years on the Cloud Dashboard?
And this is weird with the Apple Watch view:
It's possible - see https://content.meteobridge.com/dashboard/52104abc6a8e6e5409f926d6a76fd511/weather34-2024-layout-3.php
click on the chart icon and then on "Charts Menu" and select the year.
However, you must have configured the Admin Dashboard accordingly.
Charts from 2019 on are possible.
EDIT :
- in the link in some years a few tiles are empty due to having used an older W34 version where these data were not recorded  - would need to update the year.csv files from CMX data and upload them (if I have the time)
- I don't that bitten of fruit brand, so can't say anything about the watch ...
« Last Edit: May 31, 2025, 03:12:41 PM by Gyvate »
WS2350 1.7.0,GW1000 1.7.7,WH2650 WiFi 1.7.7,GW1100 2.3.7,GW1200 1.3.4,GW2000 3.2.1,GW3000 1.0.3,HP2550 2.0.1,5.1.9; HP3500 1.7.2,WS3800 1.3.4, WS3910 1.3.4, WN1910 1.2.4,WN1820/WN1980 1.3.5;
Ecowitt WS90, WS85, WS80, WS68, WS69, WN30, WH31,WH31-EP, WH32,WH32-EP, WH32B/WN32P, WN34D,L,S,  WN35,WH40, WH41[PM2.5], WH45, WH46D, WH51, WH55, WH57, LDS01
Blake-Larsen Sun Recorder - RPi4/weewx 4.10.2/CumulusMX 4063/MeteobridgePro 6.1,Meteobridge RPi4B-2GB,MB VM
Barani Meteoshield Pro,MetSpecRad02,SMarTCELLino;Dracal BAR20
WIKI https://meshka.eu/Ecowitt/dokuwiki
Offline davidmc36
  • FN25IE61IX
    • MorewoodW34
« Reply #27 on: May 31, 2025, 06:23:28 PM »
I have always selected that I have data from 2019 01 01 and told it to display it.
Scheme 3 did not make any difference.
Offline Gyvate
« Reply #28 on: May 31, 2025, 06:56:15 PM »
1. did you select yes for both questions ?
Do You have data for charts from 2019
Do You have data for charts from last year
2. where did you put your year.csv files - they are not supposed to be inside the year folder !
they have to be one level higher
Offline davidmc36
  • FN25IE61IX
    • MorewoodW34
« Reply #29 on: June 01, 2025, 01:41:36 AM »
I did select yes for both. It must be the structure then. A new data pluck and upload will fix that.
Offline docbee
    • smartbedded
« Reply #30 on: June 01, 2025, 06:38:01 AM »
May be easiest way to get data from older Aurora installs to Meteobridge Aurora Cloud is to use the "Clone Data" option from within Meteobridge Aurora Admin page. Simply select the URL where your current install resides and be patient. It can take a few minutes until the download to a local archive file on your PC starts. Having that you can upload this archive to Meteobridge Aurora Cloud from your PC.
Remark: It needs you to have the latest Aurora version installed on the Website you want to clone from (May 2025).
Offline Gyvate
« Reply #31 on: June 01, 2025, 06:48:12 AM »
when the conditions are fulfilled, yes, however ...
That's why the simple download from the new cloud installation and adding/overwriting the the year.csv in the archive will work in any case as it already brings the new structure independent of the Aurora version you take the year.csv files from:
- download from the Aurora Cloud Dashboard
- open with 7-Zip File Manager
- click on the archive (opens and displays the structure)
- drag and drop the year.csv files into the archive root
- close 7-Zip and save the updated archive
-upload
This works independent of the Aurora version.
Offline davidmc36
  • FN25IE61IX
    • MorewoodW34
« Reply #32 on: June 01, 2025, 06:49:39 AM »
I likely have an older version on my site. Have not checked that in ages.
I got the files anyway.
The Cloud Dashboard is better than my original Aurora. I cannot see the previous years on original Aurora.
Offline Gyvate
« Reply #33 on: June 01, 2025, 06:58:04 AM »
The original W34 Aurora didn't have the restrictions which were caused by the licensing (private)of the graphics once used with MB (commercial).
For the "original" MB Aurora, you had to modify some php files and copy them regularly back after MB updates as they would be overwritten.  8-)
Now these issues have been removed by the commercial licensing.  [tup]
Offline davidmc36
  • FN25IE61IX
    • MorewoodW34
« Reply #34 on: June 01, 2025, 08:46:38 AM »
Hmmmm. It's odd. I told Original that I had files from 2019, I never had that chosen before. I now see a "2024" chart available, but when I navigate it shows 2019 at the top of charts and they are blank. I don't actually have any 2019 files.
Must be the way files are stored on my hosting server?????
Offline Gyvate
« Reply #35 on: June 01, 2025, 09:06:46 AM »
for almost each year there is a separate php script in W34 - for some years it is combined into one php script.
The result is a year.csv file. The chart presentation is different for certain year groups as the development made progress - hence different data content, different php scripts.
Whatever year.csv files you have, put them into the MB Aurora root directory (in the archive into the root level).
Maybe you first check if the file structure is correct:
see WiKi https://meshka.eu/Ecowitt/dokuwiki/doku.php?id=dataloggers#the_meteobridge_aurora_dashbaord
Open the file in Notepad or Excel and check -
the field sequence has to be the same - a record can be smaller (shorter), then simply the data isn't show - if the sequence is wrong, it's likely to show rubbish or nothing.
Offline davidmc36
  • FN25IE61IX
    • MorewoodW34
« Reply #36 on: June 01, 2025, 12:33:14 PM »
When I check Admin Login for my own hosted Aurora, it says my version is: "Your Current PHP version is : 7.4.33"
I see Humidity and Wind Direction are mostly missing from charts.
I looked at a month.csv. The end of the lines are wrong from SOL RAD MAX onward. Not enough entries and one is blank.
I see the wind and humidity on the daily chart in the Cloud, so once month and year charts are generated, those new ones should look fine too.
Offline Gyvate
« Reply #37 on: June 01, 2025, 03:01:15 PM »
for the new ones yes - they will be properly created.
For my old ones, I edited the old year.csv files (so far 2020 and 2024 as I had a W34 V. 9.35) in Notepad and added the solar, UVI, wind direction and humidity values from my CumulusMX dayfile.
2021 - 2023 still to go (~1300 records to be updated)
Missing entries at the end of a record are just missing - as long as the sequence before is OK, missing entries can be marked --
Offline davidmc36
  • FN25IE61IX
    • MorewoodW34
« Reply #38 on: June 01, 2025, 03:11:57 PM »
I don't think I will bother editing any files. I have all the data viewing I need in CMx.
Offline davidmc36
  • FN25IE61IX
    • MorewoodW34
« Reply #39 on: June 01, 2025, 03:13:44 PM »
Any clue if this is a bug?
