Author Topic: HTTP Error Saratoga Meteobridge upload Fails  (Read 1663 times)
Offline ed_heaton
    • Atglen Borough Weather Observatory
« on: April 11, 2025, 10:28:00 AM »
Good morning,
Is this a server error with my hosting service or my issue? I haven't changed anything on my end and it was working fine two days ago...
[Fri Apr 11 07:01:15.715113 2025] [autoindex:error] [pid 195420:tid 22708972353280] [remote 76.99.112.52:63393] AH01276: Cannot serve directory /home4/elheaton/public_html/ajax-images/: No matching DirectoryIndex (wxindex.php) found, and server-generated directory index forbidden by Options directive, referer: https://www.atglenweather.com/
« Last Edit: April 11, 2025, 12:58:40 PM by ed_heaton »
Offline wvdkuil
  • Wim van der kuil
Re: HTTP Error
« Reply #1 on: April 11, 2025, 11:54:03 AM »
Good morning,
Your MB uploads are empty.
F.i. Nearly no data in MBrealtime.txt
-- -5.6 0 : : : : : : 0.0 0.0 --- --- 0 --No data in MBtags.php either
Better restart your Meteobridge and check if it gets the data from your weatherstation.
Succ es,
« Last Edit: April 11, 2025, 11:57:48 AM by wvdkuil »
Offline ed_heaton
Re: HTTP Error
« Reply #2 on: April 11, 2025, 12:01:43 PM »
Thanks and I have restarted the Meteobridge. It is getting data because it's sending it to other sites just not my website.
Offline wvdkuil
  • Wim van der kuil
Re: HTTP/ FTP Error Saratoga Meteobridge upload Fails
« Reply #3 on: April 11, 2025, 12:39:01 PM »
Seems strange that both HTTP upload and FTP upload fail.
The HTTP upload gives a 409 error according to your screenshot.
But what is the error for the FTP upload of MBtags.php ?
Hope this topic will attract attention of other specialists.
Please modify the topic description in your first post to get more attention
F.i. HTTP/ FTP  Error Saratoga Meteobridge upload Fails
« Last Edit: April 11, 2025, 12:41:13 PM by wvdkuil »
Offline ed_heaton
Re: HTTP Error
« Reply #4 on: April 11, 2025, 12:50:21 PM »
The FTP did not fail...  Only the HTTP
Offline wvdkuil
  • Wim van der kuil
Re: HTTP / FTP Error Saratoga Meteobridge uploads Fail
« Reply #5 on: April 11, 2025, 01:12:47 PM »
The MBtags.php is empty as far as I can see.
https://www.atglenweather.com/check-fetch-times.php?show=wx
https://www.atglenweather.com/MBtags.php?sce=dump
As a result, your website has no data, all fields are empty.
« Last Edit: April 11, 2025, 01:15:26 PM by wvdkuil »
Online saratogaWX
Re: HTTP Error Saratoga Meteobridge upload Fails
« Reply #6 on: April 11, 2025, 02:54:19 PM »
Use meteobridge to reload the MBtags.php template from http://www.atglenweather.com/gen-MBtags.php
Note that the meteobridge template reload does not support https, so if you have a website setting to automatically redirect http to https, turn it off before having meteobridge reload the template.  After the successful upload of data in MBtags.php, you can turn on the website redirect of http to https again.
« Last Edit: April 11, 2025, 02:57:48 PM by saratogaWX »
Offline ed_heaton
« Reply #7 on: April 11, 2025, 05:50:03 PM »
Thanks for all the help guys!!!  It apparently was on the hosting end because miraculously it started working again!!!
Offline hcorrin
    • Ballaugh Weather
« Reply #8 on: April 12, 2025, 04:04:58 AM »
Your realtime file is not updating as of 4am your time 9am my time (utc+1)
Offline ed_heaton
« Reply #9 on: April 12, 2025, 05:00:47 PM »
Yep started acting up again last night :-(
