Author Topic: Saratoga Contact PHP not working  (Read 1282 times)
Offline 92merc
  • BismarckWeather.net
« on: December 19, 2024, 01:25:27 PM »
Anyone else having issues with the Contact Us PHP form?  I'm using the number LP version currently.  But I tried the hCapcha version as well.  Neither one is working at the moment.
I have the same PHP running on my home Synolgy NAS test server as my main site, and it doesn't work there either.  So I don't think it's my host that causing the issue.
I've tried changing from my ISP email to Gmail.  Neither get the emails, even though the site claims it was sent.
Only reason I figured out it wasn't working is I looked at my contact-loglp.txt file for logging and it had a couple of people I didn't get emails from.  Guessing from the log vs. my emails, it probably quit sometime this summer.  I'm not seeing any errors in my main hosting error logs either.  Only entry was when I misconfigured the hCaptcha version.  Once I fixed that, it still didn't go out.  I've ditched that version since it seems some bots can get by it.
https://www.bismarckweather.net/wxcontact.php
Offline Otis
  • (aka Paul)
    • Lake Huron Weather
Re: Saratoga Contact PHP not working
« Reply #1 on: December 19, 2024, 01:35:28 PM »
Funny you bring this up, I just checked mine (LP version) this morning.
Mine is working.
Never did have success with getting a gmail account to work.
CW3699
Offline 92merc
« Reply #2 on: December 19, 2024, 02:12:57 PM »
I have an email forwarder with my hosting plan.  It forwarded my single bismarckweather.net email address to my ISP email.  That didn't work either.
« Reply #3 on: December 19, 2024, 05:35:44 PM »
Definitely, the contactLP is much more resistant to hackers than the Google reCaptcha and the hCaptcha versions
It may be that your mailer doesn't like having a From: header in the message which doesn't match YOUR userid@hostname, but will allow a Reply-to: header.
Try changing contactLP-inc.php from
   mail($mailto,$subj,$msg,"From: $EMname <$EMaddress>\r\nReply-to: $EMname <$EMaddress>");
to
   mail($mailto,$subj,$msg,"Reply-to: $EMname <$EMaddress>");
As many hosters tighten up email rules, third-party From: headers are now mostly bounced.  I had the same issue with mine.
Offline 92merc
« Reply #4 on: December 20, 2024, 08:43:45 AM »
Still not working.  I even changed my email address back to my forwarder bismarckweather.net account.
« Reply #5 on: December 20, 2024, 08:56:12 AM »
You need to test your mail() function's connection to your outbound mail engine.
Try using the following script (script name not important)
<?php
error_reporting(E_ALL);
ini_set('display_errors','1');
$msg = "Test of email output\n";
$to = "you@yoursite.com"; // <== change to your email address
$state = mail($to,'Outbound mail test',$msg,"Reply-to: $to");
print $state?"Mail to '$to' accepted.":"Mail to '$to' FAILED.";
Tthat will show if your PHP/website mailer is correctly configured.
Offline 92merc
« Reply #6 on: December 20, 2024, 09:23:29 AM »
https://www.bismarckweather.net/phpmailtest.php
Mail to 'bw@bismarckweather.net' accepted.
Offline 92merc
« Reply #7 on: December 20, 2024, 09:27:44 AM »
I did just test my forwarder email address.  So that bw@bismarckweather.net is forwarding to my ISP email.  So at least I know that part is working.
