Author Topic: ICDSoft Hosting  (Read 2796 times)
Offline 92merc
  • BismarckWeather.net
ICDSoft Hosting
« on: December 05, 2024, 11:37:52 AM »
I was doing a chat with ICDSoft to move my hosting and DNS to them.  They provide Let's Encrypt certificates, which is what I'm using currently.
When I asked them if their CPanel lets you download the certificates so I can use them on my home web servers, they said no.  I find that odd.  Can anyone with ICD confirm that?
When I go into my GoDaddy CPanel, I have a section that I can manage my certificates.  That includes viewing them to copy/paste the data into cert files.  I would have thought that was a feature baked into CPanel.
Offline davidmc36
  • FN25IE61IX
    • MorewoodW34
Re: ICDSoft Hosting
« Reply #1 on: December 06, 2024, 03:57:28 AM »
The only thing I see in the Let's Encrypt area is ability to Enable/Disable for each domain and sub-domain.
Offline 92merc
Re: ICDSoft Hosting
« Reply #2 on: December 06, 2024, 08:40:13 AM »
Bummer.  I was really hoping to switch.  I run 6 subdomains at home, plus a few personal devices I put that cert on.
Thanks for checking.
Offline Mapantz
    • Wareham Weather
Re: ICDSoft Hosting
« Reply #3 on: December 23, 2024, 05:50:32 PM »
Shouldn't it be under "Security" SSL/TLS?
SSL/HTTPS according to this example: https://www.icdsoft.com/en/hosting/controlpanel
Is it me, or does that look like cpanel from the 90's?
« Last Edit: December 23, 2024, 05:54:35 PM by Mapantz »
Offline 92merc
Re: ICDSoft Hosting
« Reply #4 on: December 24, 2024, 08:35:10 AM »
I found that sample Control Panel after I made my last post.  I was able to see what I needed.
What's weird is ICD will do an automatic Let's Encrypt cert.  But they won't give you access to it in the panel, so that you can use it elsewhere.  I use my certs on my home systems as well.  So I need access.
I could use my current method of using Certify the Web program and renew the certs.  But I'd still be manually installing them like I am now to my host.  I was hoping to avoid that.
No matter.  After some testing, I think I'll be going to self hosting on my Synology next year when my hosting is due.
Thank you
Offline davidmc36
  • FN25IE61IX
    • MorewoodW34
Re: ICDSoft Hosting
« Reply #5 on: February 07, 2025, 02:01:02 PM »
I hope I didn't deny you of info.
I really didn't know enough about what is actually on the CP.
Once I had enabled Let's Encrypt, I see the export section.
D
Offline 92merc
Re: ICDSoft Hosting
« Reply #6 on: February 07, 2025, 02:07:27 PM »
No, it's all good.  I got the info I needed thank you.
