Author Topic: testtags.php and clientraw.txt issue  (Read 2287 times)
Offline JesseLikesWeather
  • Jesus is LORD
    • Milton Weather Ranch
« on: November 30, 2024, 10:43:04 AM »
Hi, I am using Weather Display Build 152 and I am using the Saratoga-Weather Base USA template, and I have been having a lot of trouble with the clientraw & testtags file being created and uploaded to my web server.
I redownloaded the plugins and even reinstalled the WD software, but nothing worked. What should I do?
JesseLikesWeather
Advanced Weather Enthusiast
Ambient WS-2000 Weather station Operator
  • Jesus is LORD
Re: testtags.php and clientraw.txt issue
« Reply #1 on: November 30, 2024, 12:40:33 PM »
Okay, I got part of it working again, the thermometer is acting up, and the time isn't displaying on the webpage.
JesseLikesWeather
Offline Vasco
    • PWS
« Reply #2 on: November 30, 2024, 02:12:51 PM »
Go to https://saratoga-weather.org/wxtemplates/install.php and find the Setup instructions for Weather Display under item 7.
« Last Edit: November 30, 2024, 02:15:15 PM by Vasco »
  • Jesus is LORD
« Reply #3 on: November 30, 2024, 07:27:33 PM »
You mean this?
7.
Edit the Settings-weather.php file and perform the weather software-specific setup, including the setup of your weather software to upload the required [WXname]tags.php file and the realtime file(s) used for the AJAX updates to your website.
The detailed instructions are found in the WXtags-template-files/README.txt file from the weather software plugin .ZIP file and at the links below. If you change directory names or units-of-measure from the defaults in the Settings.php and Settings-weather.php files, make the corresponding changes to the ajax[WXname]wx.js file in your site
JesseLikesWeather
Offline Vasco
    • PWS
« Reply #4 on: November 30, 2024, 07:31:39 PM »
See attachment.
  • Jesus is LORD
« Reply #5 on: November 30, 2024, 07:32:30 PM »
Ah, I see. Sorry for the confusion.
JesseLikesWeather
  • Jesus is LORD
« Reply #6 on: November 30, 2024, 07:50:04 PM »
..didn't work sadly :-(
JesseLikesWeather
  • Jesus is LORD
« Reply #7 on: December 01, 2024, 07:25:16 PM »
The clientrawhour file isn't being produced for some reason. I have it set to "create a clientawhour file every five minutes".
JesseLikesWeather
Offline Vasco
    • PWS
« Reply #8 on: December 01, 2024, 07:33:05 PM »
You may need to restart WD when you change an FTP setting.
Offline hcorrin
    • Ballaugh Weather
« Reply #9 on: December 02, 2024, 05:32:07 AM »
How are you doing that the clientrawhour file is created hourly by WD usually 1 min to the hour and normally uploaded by the clientrawrealtimeftp with the other clientraw files
Check the modified file time and date in folder the clientraw files are in
  • Jesus is LORD
« Reply #10 on: December 02, 2024, 11:58:13 AM »
Okay, double-checked my FTP settings, they were correct, but nothing seemed to have worked
I apologize for all of this.
JesseLikesWeather
  • Jesus is LORD
« Reply #11 on: December 02, 2024, 12:10:23 PM »
Apparently my webfiles are still not updating, hopefully that is the issue. I am having to manually update them by doing in Weather Display:
> Action
> Update Files and Webcam Now
JesseLikesWeather
  • Jesus is LORD
« Reply #12 on: December 02, 2024, 02:15:39 PM »
Looks like I got clientraw.txt working once again, just need to get the testtags file working now.
JesseLikesWeather
Offline hcorrin
    • Ballaugh Weather
« Reply #13 on: December 03, 2024, 04:28:03 AM »
When I checked your status page the file were updating but the page is getting a fatal error due to the template-version-info being missing in the cache folder check your file permissions on the folder and files within are high enough to allow them to be created and written too
  • Jesus is LORD
« Reply #14 on: December 03, 2024, 08:54:21 AM »
I'm using altervista, haven't activated server to server, so that is going to be a common error I believe.
JesseLikesWeather
  • Jesus is LORD
« Reply #15 on: December 03, 2024, 08:54:59 AM »
Otherwise the file uploading seems to be working just fine, I had to completely uninstall then reinstall the program.
JesseLikesWeather
« Reply #16 on: December 03, 2024, 02:45:06 PM »
Yes, on altervista sites, you MUST enable external website access for many of the template scripts to work correctly.  Otherwise, no forecasts for weather nor UV will be available.
  • Jesus is LORD
« Reply #17 on: December 04, 2024, 12:22:55 PM »
Other than the server-to-server activation not being present, everything seems to be working just fine. Thank you everybody!!  :grin:
JesseLikesWeather
