Author Topic: XML Error  (Read 471 times)
Offline Jumpin Joe
    • Joe’s Weather
XML Error
« on: September 13, 2020, 01:35:26 PM »
Getting an XML error message after updating my scripts, www.joesweather.info
XML error: Invalid document end at line 94
and I do not know where to go to find it or fix it.
Can anyone help me?
Joe
https://joesweather.info
WeatherLink Live
Offline wvdkuil
  • Wim van der kuil
Re: XML Error
« Reply #1 on: September 13, 2020, 01:52:24 PM »
Can anyone help me?
Joe
Check your https://www.joesweather.info/flyout-menu.xml
error on line 94 at column 1: Extra content at the end of the document
XML Parsing Error: junk after document element
Line Number 94, Column 1:
Wim
« Last Edit: September 13, 2020, 01:54:28 PM by wvdkuil »
Offline Jumpin Joe
    • Joe’s Weather
Re: XML Error
« Reply #2 on: September 13, 2020, 02:42:39 PM »
Thank you, once again, Wim!
That corrected it.
Can you tell me how you found the error so I can correct issues like this on my own from now on?
Joe
Can anyone help me?
Joe
Wim
WeatherLink Live
Offline wvdkuil
  • Wim van der kuil
Re: XML Error
« Reply #3 on: September 14, 2020, 03:28:45 AM »
That corrected it.
Joe
In your browser run https://www.joesweather.info/
=> Right click and select  from the pop-up menu "show html" (or similar wording)
==> Only a few lines are there, the last one is  the <title> line
Use https://www.joesweather.info/check-fetch-times.php?show=structure
=> scan for <title>
==> that is displayed just before loading the flyout-menu.php script
That script https://www.joesweather.info/flyout-menu.php?sce=view loads an  xml - file of the menu
==> as set in line 21 $MENUdef = './flyout-menu.xml';
==>  open that file  https://www.joesweather.info/flyout-menu.xml  in the browser and the error is displayed.
Wim
