Author Topic: Can't Set to mi in Earthquake Script  (Read 493 times)
« on: August 03, 2020, 03:44:37 PM »
Even though I seem to be doing it right, I can't set the Earthquake page to use mi, rather than km for the epicenter near column.  Or is it not possible to set to mi there?    Here are the two settings I use in quakejason.php:
# uncomment ONE of the $setDistanceDisplay lines to use as template for distance displays
#  $setDistanceDisplay = 'mi (km)';
    $setDistanceDisplay = 'mi';
#  $setDistanceDisplay = 'km (mi)';
#  $setDistanceDisplay = 'km';
// setting for how to display distances .. uncomment one below
// note: will be overridden by $SITE['distanceDisplay']  or $setDistanceDisplay if it exists
//  $distanceDisplay = 'mi (km)';   // display for distances in 'N mi (K km)'
    $distanceDisplay = 'mi';   // display for distances in 'N mi'
//  $distanceDisplay = 'km (mi)';   // display for distances in 'K km (N mi)'
//  $distanceDisplay = 'km';   // display for distances in 'K km'
https://stillwaterweather.com/okareaearthquakes.php
Re: Can't Set to mi in Earthquake Script
« Reply #1 on: August 03, 2020, 04:54:43 PM »
It seems you made the change inside a /* ... */ comment, instead of later on in the actual code to be executed
(after the // settings: --------------------------------------------------------------------  line).
Look further down, and you'll see that
//  $distanceDisplay = 'mi';   // display for distances in 'N mi'
is the one being executed.  Change that to
I find it's really helpful to have a syntax-highlighting editor (like Notepad++ or PHPStorm or Dreamweaver) to show what's a comment and what is code to be executed.
« Last Edit: August 03, 2020, 05:01:32 PM by saratogaWX »
