Author Topic: Validation Errors in wxforecast.php  (Read 697 times)
Offline jachen
    • Neue Wetterstation Widen
« on: April 12, 2019, 11:06:57 AM »
Hello all
 I probably screwed up something when updating from Wunderground (WU) fo WC.forecasts and get the lines below into source code causing the page not to validate.
Question: What causes these lines to be parsed?
<div id="main-copy">
         <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN"
    "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
https://meteo.widen-online.ch
Thanks a lot for any ideas.
jachen
Re: Validation Errors in wxforecast.php
« Reply #1 on: April 12, 2019, 11:49:08 AM »
If you're using the WC-forecast.php to replace the WU-forecast.php script, the calling page has to be a bit different:
<?php
$doIncludeWC
true;
include(
"WC-forecast.php"); ?>
instead of the old WU-forecast script which used
<?php
$doIncludeWU
true;
include(
"WU-forecast.php"); ?>
Offline jachen
« Reply #2 on: April 12, 2019, 01:51:47 PM »
Thank you Ken
I read that on your description under "Usage Samples" but my brain didn't follow exactly where to put the code. "The calling page" was the key. I am very old. Better in gardening.
Have a good weekend.
