Author Topic: Support of the "Leuven" Forecast scripts  (Read 87579 times)
Offline wvdkuil
  • Wim van der kuil
Re: Support of the "Leuven" Forecast scripts
« Reply #50 on: April 02, 2021, 04:33:00 AM »
Hi
Could I please have help to fix this problem  All was good until yesterday.  I have not changed any script.  My website is:  https://www.kstwx.net/wxnorwayfcst.php.  The first attachment is a screenshot from my desktop whilst the second is what appeared on my iPad today.  Yesterday both appeared on my desktop (Win 10).
Keith
Thanks for using the Leuven forecast script.
Never knew there was a user of them in Australia https://support.leuven-template.eu/userlistScripts.php
Answered in this topic with post #41 by @kyomar and #42 by me, just before your question:
https://www.wxforum.net/index.php?topic=36478.msg426228#msg426228
As you are using an older version, the line numbers are:
wsMetnoCreate.php => line 52
wsUFct4.php => line 58
« Last Edit: April 02, 2021, 04:56:36 AM by wvdkuil »
Offline griffo42
    • Carina Weather
« Reply #51 on: April 02, 2021, 09:07:48 PM »
Hi
Thanks for your quick response:  all fixed.  By all means, add me to the users list for Norway forecasts.  https://www.kstwx.net/index.php.
best wishes
Keith
Davis Vantage Pro2 Model #6152AU
CumulusMX latest version
Saratoga Weather World template Cumulus plugin
Carina Weather, Brisbane.
Offline MarkDM
    • Weerstation Berlare
« Reply #52 on: April 08, 2021, 12:31:02 PM »
Hello,
I noticed my forecast page was not working anymore. Thanks to this thread a found the cause.
But there is a problem in the solution. The script is working, even stand-alone without enclosing html:
https://weerstationberlare.be/wsfct4/wsFctMetnoPage4.php
I adapted the file wsMenuData.xml for it:
<item   nr      = "wsForecast"
        caption = "Forecast"
        link    = "wsfct4/wsFctMetnoPage4.php"
        gizmo   = "1"
This not working, the menu-button "Vooruitzicht" (translated) keeps pointing to the old target:
Is there something else I have to activate ? It doesn't seems a cache problem.
Offline wvdkuil
  • Wim van der kuil
« Reply #53 on: April 08, 2021, 01:02:07 PM »
Hello,
        gizmo   = "1"
This is a thread for the stand-alone (+Saratoga) forecast scripts.
They are not integrated with the Leuven-Template. They are having multiple errors as they are not positioned at the correct folder.
Warning: include_once(./ws_set_environment.php): failed to open stream: No such file or directory in /home/uitber1q/weerstation/wsfct4/wsFctMetnoPage4.php on line 144
Warning: include_once(): Failed opening './ws_set_environment.php' for inclusion (include_path='.:/opt/alt/php70/usr/share/pear') in /home/uitber1q/weerstation/wsfct4/wsFctMetnoPage4.php on line 144
Warning: include(./_metric_settings.php): failed to open stream: No such file or directory in /home/uitber1q/weerstation/wsfct4/wsFctMetnoPage4.php on line 146
Warning: include(): Failed opening './_metric_settings.php' for inclusion (include_path='.:/opt/alt/php70/usr/share/pear') in /home/uitber1q/weerstation/wsfct4/wsFctMetnoPage4.php on line 146
Fatal error: Uncaught Error: Call to undefined function ws_debug_times() in /home/uitber1q/weerstation/wsfct4/wsFctMetnoPage4.php:152 Stack trace: #0 /home/uitber1q/weerstation/index.php(331): include() #1 {main} thrown in /home/uitber1q/weerstation/wsfct4/wsFctMetnoPage4.php on line 152
It is a lot more work  to use the stand-alone scripts. https://weerstationberlare.be/wsfct4/readme.html
You need to run them in an iFrame if using them in any template.
Better use the built-in version in the Leuven Template
The UV and MetNo forecast scripts in the Leuven-Template need only a small modification
=> https://support.leuven-template.eu/problems28.php?lang=nl
Or on the HWA forum at https://www.hetweeractueel.nl/forum/viewtopic.php?f=226&t=70313&sid=b89f274a86cca82b4948c976598fada3#p73098
« Last Edit: April 08, 2021, 01:09:20 PM by wvdkuil »
Offline MarkDM
« Reply #54 on: April 08, 2021, 03:10:24 PM »
Thank you Wim.
It works again with this small modification on the original script.
Regards,
Offline lacouste
« Reply #55 on: October 05, 2021, 04:09:57 AM »
hello everyone today all of the forecast scripts have stopped working. i thought the met.no is going to keep working that seems to have shut down as well. What gives on your side. Good day to you
i havz that on all yr met no ect.....
no forecast data can be retrieved, check the html for errors
« Last Edit: October 05, 2021, 04:12:34 AM by lacouste »
Offline wvdkuil
  • Wim van der kuil
« Reply #56 on: October 05, 2021, 04:52:46 AM »
Hi @lacouste,
I am confused about the word "all in your message"
I currently support 9 different forecast scripts. Only 1 has some intermittent problems until February 1, 2022 and will stop working on that date.
As announced end of 2020 by Yr.no  their xml-forecast will not be functional in the near future.
From  October 1st, the yr.no forecasts API in the current format, example  https://www.yr.no/place/Belgium/Flanders/Herent/varsel.xml has indeed "man-made" problems to warn you of that change.
This is their message they will return for a few days, then they will supply the data again for a few day/weeks and that message / data will be repeated until February 1 next year.:
This service will be retired on February 1st, 2022. Please go to https://developer.yr.no/doc/guides/getting-started-from-forecast-xml/ to get started with our new API. This service will have random interuptions until the final end of life date February 1st, 2022.
When you read the information on the developer.yr.no pages, you see that they switched to using met.no data directly.
THEREFOR there is no need to develop a new yr.no script as the data is identical as used in the current met.no script.
The met.no forecast scripts works without problems, now and in the "foreseeable" future.  ;)
Regards,
P.S. I started with 12 forecast scripts and indeed 4 data-sets are not available anymore.
Not bad for scripts from 2015-2018 also considering that only 18 users helped supporting those scripts directly.
Offline lacouste
« Reply #57 on: October 05, 2021, 05:34:59 AM »
hello kim I am also confused because as you announced yn.ro had to stop working so for that no problem on the other hand in my wsfct4 folder the rest of the programs no longer work also I still have error messages
for http://meteolimoux.fr/wsfct4/wsFctDarksPage4.php
 I have This scripts needs an API-key, please check the docs
for metno http://meteolimoux.fr/wsfct4/wsFctMetnoPage4.php I have no forecast data can be retrieved, check the html for errors
for http://meteolimoux.fr/wsfct4/wsFctWuPage4.php I have This scripts needs an API-key, please check the docs
for http://meteolimoux.fr/wsfct4/wsFctWxsimPPage.php I have Error input file not found, cache file not found either => ../ complaintxt.txt
Scripts failed, check html for problems
for yahoo I have No data was retrieved for https://query.yahooapis.com/v1/public/yql?q=select+*+from+weather.forecast+where+woeid+in+(SELECT+woeid+FROM+geo .places + WHERE + text = "(43.071812,2.217438)") + & format = json
all the programs no longer work in my folder
Offline wvdkuil
  • Wim van der kuil
« Reply #58 on: October 05, 2021, 05:53:21 AM »
I think you maybe have an old download?
Please check the current working scripts
===> https://www.weerstation-herent.be/wsfct4/
WU an Yahoo stopped years ago, they are therefor not in the demo.
Yr.no will have the "nag" message for a few days and will on/off work again until Februari next year.
DarkSky always needs an API-key, the scripts will work at least to end of December 2022.
But DarkSky will not accept new users as it was bought by Apple. If you have no DarkSky api key, the scripts will not work.
WXSIM can only be used when you have the paid-for WXSIM forecasting programs (windows only) and upload the data files to your web-site.
Met.no should work, but the API url changed so check these two topics for the answer here
There the change needed in line 50 of wsIncMetnoCreate.php is described
@ALL Please always check the support => demo-site and see if it works there.  [tup]
« Last Edit: October 05, 2021, 05:55:22 AM by wvdkuil »
Offline lacouste
« Reply #59 on: October 05, 2021, 07:18:17 AM »
hi wilm i made the modification on line 50 but i get this error message
unknown error Warning: file_put_contents(./cache/wsIncMetnoHtml4_c_mm_kmh_hpa_cm_km_43-071812_2-217438.arr): failed to open stream: No such file or directory in /customers/5/5/d/meteolimoux.fr/httpd.www/wsfct4/ws_set_environment.php on line 181
ws_save_cache: ERROR Could not save data to cache (./cache/wsIncMetnoHtml4_c_mm_kmh_hpa_cm_km_43-071812_2-217438.arr).
Please make sure your cache directory exists and is writable.
Program ends
Offline wvdkuil
  • Wim van der kuil
« Reply #60 on: October 05, 2021, 07:32:10 AM »
Program ends
I think the message (in red) is very clear.
Are you sure you have officially downloaded the scripts between 2018 and today?
There should be a folder with the name "cache", it should be in your  wsfct4/  folder in your download area in your pc/mac also.
Normally when you upload the wsfct4 folder from the pc/mac to your webserver, all folders and scripts are copied and ​get the same "rights" as in the download.
So it is nearly impossible that the cache/ folder is not there.  Check your download folder.
Or use your FTP program to create a cache folder inside your  wsfct4 folder.
If you check the contents of your wsfct4 folder it should look more or less like this screenshot, 7 folders and a lot of scripts.
« Last Edit: October 05, 2021, 07:34:28 AM by wvdkuil »
Offline lacouste
« Reply #61 on: October 05, 2021, 12:00:00 PM »
I just looked I downloaded the folder on 08/02/2018 I don't have a cache file in the meteolimoux.fr / wsfct4 / subfolder
I have img, js, lang, other, pp, saratoga root, on the other hand I have a cache file in the img folder
https://filemanager.one.com/#matthieu.coustal@wanadoo.fr/meteolimoux.fr/files/wsfct4/img/cache/
Offline wvdkuil
  • Wim van der kuil
« Reply #62 on: October 05, 2021, 12:02:29 PM »
You need a cache folder inside the wsfct4/ folder.
That is what is needed for the scripts to save the data as downloaded from met.no
Succes,
Offline lacouste
« Reply #63 on: October 05, 2021, 12:11:46 PM »
ok can I simply create it manually in my manger file from my web folder?
Offline wvdkuil
  • Wim van der kuil
« Reply #64 on: October 05, 2021, 12:16:33 PM »
Yes, I hope so.
Also check if the error goes away after  that.
If not use your FTP program ow whatever to give the correct permissions.
Offline lacouste
« Reply #65 on: October 05, 2021, 12:22:43 PM »
thank you wilm it works now thank you =D&gt;
Offline ha-rob
    • UranusWeather
« Reply #66 on: November 11, 2021, 11:20:30 AM »
Hello. I have used the Leuven template for many years. I have not done any changes in the script for a long time. A few days ago the script stopped working. Only a completely empty, grey page appears when typing the url: www.uranusweather.com
I hope for some help to fix this.
Best wishes :-)
Rob
Offline wvdkuil
  • Wim van der kuil
« Reply #67 on: November 11, 2021, 12:16:43 PM »
Best wishes :-)
Rob
Hi Rob,
PHP-version:
Checking with info.php => your provider or you yourself changed your website  to using PHP Version 8.0.12
That is a big change from 5.6 or 7.4 for which the template was tested.
And you will probably run into far more errors, if you continue to use PHP 8.0.xx versions for this template.
This topic you posted this question is for the Leuven-Forecast scripts discussion but your problem is in the Leuven-Template.
Next time,  post your questions in the template topic https://www.wxforum.net/index.php?topic=36504.0
Debug:
Running your website with "?debug=yes" shows the error is in wsAjaxDataLoad_v3.php
Parse error: syntax error, unexpected token "-",
expecting "]" in /customers/a/6/7/uranusweather.com/httpd.www/weather2/wsAjaxDataLoad_v3.php on line 451
The error  is a "parse error" and signals the script contains invalid PHP, and all further processing stops after a parse error.
So indeed you will have an empty grey page.
Script-source:
Listing the script with https://www.uranusweather.com/weather2/printScript.php?echo=wsAjaxDataLoad_v3.php
Line 451 is a comment line in your version and should not be parsed at all.
Seems a problem with the PHP-parser to me, not with the script.
Solution:
I copied your script and tested it with PHP 8.0.12 at my test-site => same error.
Change line 451 of your weather2/wsAjaxDataLoad_v3.php  from
#[forecast-text]to
# [forecast-text]Adding that extra space between the # and the rest of the comment removes the parsing error.
Offline ha-rob
    • UranusWeather
« Reply #68 on: November 11, 2021, 04:15:14 PM »
Best wishes :-)
Rob
Hi Rob,
PHP-version:
Debug:
Script-source:
Solution:
#[forecast-text]to
Many thanks for your quick response, Wim,
I checked my email inbox and found an email from my provider some weeks ago where they notified me about a future php upgrade to version 8.0. So you have right. Thatīs the reason for my problems. I have tried the solution you suggested, but unfortunately it didnīt work. What I did instead, was to roll back to php version 7.4. But the sad thing is that my provider says the version 7.4 reaches "end of life" at 2022.11.28.
But so far so god. And I apologize for posting this in the wrong topic. Anyway, thanks for your tip.  [tup]
Rob
Offline frisby75
    • Reggello Ambiente (FI)
« Reply #69 on: December 09, 2021, 06:38:37 AM »
Hello,
I installed your Forecast scripts, but how do I set the Italian language? I put the file in the "lang" folder, set in the php file: lang: "it" but it doesn't translate it for me, why?
Thank you
@ALL  PLEASE ALWAYS INCLUDE THE URL TO YOUR WEBSITE / SCRIPT
As from now, no answers if you do not include the links.
@metosa
I will use the Italian language as example, but it works the same for most western languages
To install 1 extra language, follow these steps
  • In the wsfct4/lang/ folder copy one of the current language files f.i. fctlanguage-en.txt and change the name to  fctlanguage-it.txt
  • DO NOT COPY any other language file you may have, use only a copy of an existing file in the lang folder
  • Carefully change all texts at the right to Italian
  • Change the allowed languages around line 250 in your settings file , in this case _metric_settings.php to contain your new language
That array to change is below the warnings about knowing what you are doing. Be careful.
#                              language settings
$ws_langs_supported = array ('en', 'nl', 'fr', 'de');
Change to
#                              language settings
$ws_langs_supported = array ('en', 'nl', 'fr', 'de','it');
This is the file with the Italian translation. Just replace the current English file in wsfct4 LANG folder
Offline pimohdaimaoh
  • "Be aware to our nature"
    • PIMOHWEATHER
Re: MetNo doesnt shown on my hosting site but it worked on Local
« Reply #70 on: January 04, 2022, 03:49:35 AM »
Hello,
After I noticed that my OLD YrNo created by Wvdkuil on my webpage is no longer functional I download your new script and to add MetNo instead.
First on my local web http://127.0.0.1 for example test it is working HOWEVER when I uploaded to my hosting site it only shows this (see attached image), I only changed the file names which are easy for me to remember inside folder where I put it but the scripts are still same intact.
http://www.pimohweather.com/YRNO.php
it supposed to be this (see the second image)
is there part on the script that dissallows to viewed on hosting site? please let me know.
regards
-Mike-
« Last Edit: January 04, 2022, 03:58:22 AM by pimohdaimaoh »
Offline wvdkuil
  • Wim van der kuil
« Reply #71 on: January 04, 2022, 03:58:56 AM »
Hello,
After I noticed that my OLD YrNo on my webpage is no longer functional I download your new script and to add MetNo instead.
regards
-Mike-
PLEASE always give a correct link to the real page with the error.
The link you supplied runs the forecast in a frame. So you waste support time to let me  scan the html to find the real forecast page used => http://www.pimohweather.com/WXYRMO/MetNo/wsMetNopage4.php
A 404 error comes from your webserver not from your website or scripts.
It simple tells you there is either a typing error in the pagename you typed
=> often capital letters and small letters really  are important on a website
==> http://www.pimohweather.com/WXYRMO/MetNo/wsMetNopage4.php   does not exist
The http://www.pimohweather.com/WXYRMO/MetNo/wsMetNoPage4.php  does exists,
=> it can find 3 other scripts
=> but fails as the wsMetNoHtml.php script is missing.
Why is it important for you to change script-names?
The  start-page from which you can easily test all scripts. can not find the script either
http://www.pimohweather.com/WXYRMO/MetNo/ clicking on the links, f.i. WU, will give a correct installation error
Clicking on the metno link will give the 404 error for http://www.pimohweather.com/WXYRMO/MetNo/wsFctMetnoPage4.php
That changing script names makes finding errors and giving support far more difficult than necessary.
And changing filenames without adapting the scripts which load the files is really not a good idea, to say it polite.
« Last Edit: January 04, 2022, 09:25:43 AM by wvdkuil »
    • PIMOHWEATHER
« Reply #72 on: January 04, 2022, 11:00:27 AM »
Hello,
regards
-Mike-
Hi wvdkuil,
My apologies if I intentionally changes the file names, I did it intentionally the reason why I change the file-names because I like it to easily remember where I put it on my hosting site just to avoid unnecessary messing my uploads to web server if ever there will be need a troubleshoot just in case. Thank you for the response and Maybe I should revert back to its original filenames and retry to upload to the webserver, maybe that might be the reason of the error on web server.
UPDATE: it is now working, I didnt noticed that my web server is sensitive in small and symbol caps which I shouldnt change, but since the original file-names are difficult for me to remember I screen shot them one by one and save it to the same folder just in case I forgot the names when someday it needs to recall. Thank You for you reply
Regards
-Mike-
« Last Edit: January 05, 2022, 01:30:39 AM by pimohdaimaoh »
Offline ghera
« Reply #73 on: January 22, 2022, 10:07:32 AM »
I found some weird code inserted in forecast template, with links to freaky/ads/porn websites.
Here is an example:
":root topadblock, :root span[id^="ezoic-pub-ad-placeholder-"], :root img[alt^="f**kbook"], :root iframe[src*="mellowads.com"], :root div[style^="padding: 5px 15px !important"] > [style^="width: 100% !important; cursor: pointer !important;"], :root div[id^="zergnet-widget"], :root div[id^="traffective-ad-"], :root div[id^="taboola-stream-"], :root div[id^="sticky_ad_"], :root div[id^="rc-widget-"], :root div[id^="q1-adset-"], :root div[id^="proadszone-"], :root div[id^="lazyad-"], :root div[id^="gtm-ad-"], :root div[id^="ezoic-pub-ad-"], :root div[id^="dmRosAdWrapper"], :root div[id^="div-gpt-"], :root div[id^="div-adtech-ad-"], :root div[id^="dfp-slot-"], :root div[id^="dfp-ad-"], :root .......+ a long similar list + { display: none !important; }
What is this all about?
« Last Edit: January 22, 2022, 04:04:05 PM by ghera »
Offline wvdkuil
  • Wim van der kuil
« Reply #74 on: January 22, 2022, 12:06:37 PM »
I had the unpleasant surprise to find some weird code inserted in forecast template, with links to freaky/ads/porn websites.
Here is an example:
Never seen this. The demo site does not has any of these in the html
Downloads untouched since 2021 March 3.
How did you obtain the scripts: Download from support site or from someone else?
What is the link to your site and to the forecast script?
