Author Topic: Need help with validation  (Read 2016 times)
Offline 96Cobra
« on: October 16, 2012, 02:59:34 AM »
I'm using a VP2, WeatherLink and Ken's "Saratoga" scripts to run my website.  I'm still tweaking and changing things and have an issue.  I changed the regional Radar image to an image/link I like but the link is filled with &s and =s and will not validate.  I assume it's expecting &amp in place of the &, but this will screw up the link.  What do I need to do to fix this? I've been using this image for years now & I like all of the customizations you can do with it.
My HTML/php/css skills are pretty much non-existant...  :lol:  ](*,)  I ran my site with the basic WeatherLink templates for a few years, and I'm now trying to update to something more modern.
My website is www.rkb2.com
The link to the radar is...
http://radblast.wunderground.com/cgi-bin/radar/WUNIDS_composite?centerlat=39.41603851&centerlon=-84.98117828&radius=150&type=N0R&frame=0&num=9&delay=15&width=640&height=480&newmaps=1&r=1277046303&smoothing=1&noclutter=1&rainsnow=1
Roger
« Last Edit: October 16, 2012, 03:02:18 AM by 96Cobra »
Offline William Grimsley
    • Newton Poppleford Weather
Re: Need help with validation
« Reply #1 on: October 16, 2012, 03:14:40 AM »
Hi Roger,
The thing you need to use is & with the ";"
Will
http://www.newton-poppleford-weather.co.uk
Davis Vantage Vue - Cumulus v1.9.4 (1084)
Weather Underground: IDEVONEX12
Met Office WOW: 717144
PWS Weather: ENG128597
Offline 96Cobra
« Reply #2 on: October 16, 2012, 04:03:13 AM »
Thanks for the quick reply! Boy, that was easy!  \:D/  I'm learning!
Roger
« Last Edit: October 16, 2012, 04:10:45 AM by 96Cobra »
« Reply #3 on: October 16, 2012, 06:00:19 AM »
Hi Roger,
No problem, I learnt that from Ken! Anything with validation I should be able to help with, so if you have any more errors I am here to help! :D
Will
Offline 96Cobra
« Reply #4 on: October 16, 2012, 05:12:12 PM »
Thanks again Will! I'm sure I'll have many more questions,  it's hard to stop tinkering!
Roger
« Reply #5 on: October 17, 2012, 02:19:04 AM »
Hi Roger,
Do you have anything I can do to help...Now?
Will
Offline 96Cobra
« Reply #6 on: October 17, 2012, 03:49:52 AM »
Hi Will,
I'm trying to add another element and started another topic on it.  It's probably another simple fix, but I'm having trouble working it out.  It's located here...  http://www.wxforum.net/index.php?topic=16952.0
Roger
« Reply #7 on: October 17, 2012, 08:39:53 AM »
Hi Roger,
Sorry, but I'm in the UK so I don't use the NWS forecast so I can't help here, and it's nothing to do with validation...
Will
