Author Topic: HP2550 Wifi Issues.  (Read 1528 times)
Offline Phil23
    • Phil's Backyard
HP2550 Wifi Issues.
« on: April 24, 2022, 07:14:42 PM »
For some reason I don't seem to be able to connect to my Wifi over the past few weeks.
I've seen lost connections before, but at this point I just can't get it online again.
This morning I can see 49 devices connected to my Omada Network & one's not getting an IP.
Got a suspicion it could be an ESP issue that I've seen with other devices.
Something to do with Multiple AP's with same SSID's.
Anyone had issues or know of a resolution?
Apparently the Wifi libraries that work correctly Scan then sort the Identical SSID's by signal strength & then use BSSID  to connect to the strongest one rather than a random from the list.
Offline eliteweathernz
  • Weather Enthusiast/ Weather Equipment Support
Re: HP2550 Wifi Issues.
« Reply #1 on: April 24, 2022, 11:19:03 PM »
I had a similar issue, I found mine would not connect to wifi following a wifi firmware update.
I reached out to Ecowitt, nothing we tried was able to bring the wifi connectivity back.
They have since sent out a new console as the wifi module on the console is now bricked/failed.
Can you see any SSIDs when you try the wifi scan function in the console settings??
Offline Gyvate
« Reply #2 on: April 25, 2022, 02:47:04 AM »
when you have some sort of mesh setup, this can create issues.
When you bring your console close to your main WLAN router / access point, does it still not connect ?
Has your router run out of IP addresses for assigning via DHCP ?
Do you also use a 5 GHz WLAN with the same SSID (to be avoided) ?
If this happened after a WiFi firmware upgrade of the console, a reboot of your WLAN access point / router may help.
Offline Phil23
    • Phil's Backyard
« Reply #3 on: April 25, 2022, 04:38:16 AM »
It may be 3m from the nearest AP & probably 6 from the next. (Wifi congestion is bad here).
No, as most devices have reservations.
In my old age I hate Static IP's where avoidable.
Much prefer  Assigned IP's from a server so I can see where every thing lives
And not assigned by Router; DHCP is Assigned by one on by 3 Win Servers. The Server has a reservation of xx.xx.xx.232 for the console.
(This comes back to the ESP devices issues I mentioned originally),
I run both bands, but with XXXX-2G & XXXX-5G SSIDS.
I do feel it came about with a firmware a version or so back, not the latest I did in the last day or so.
Offline Gyvate
« Reply #4 on: April 25, 2022, 04:46:43 AM »
there were some reports in the forum in this respect. A DNS server issue was also involved. Maybe some router cache needs to be flushed and rebuilt. After a router reboot the connect would work again in a stable manner in the reported case (@hiljolodewijk).
« Reply #5 on: April 25, 2022, 05:10:04 AM »
Hey Gyvate,
In my case I can’t even get the console to register any SSIDs in the wifi scan area.
It’s not visible to any other devices either.
Ecowitt support said it’s likely a bad partition on the wifi module and when the firmware update took place it completely f**ked it for a better word.
Offline Gyvate
« Reply #6 on: April 25, 2022, 06:45:41 AM »
but at least they are sending you a replacement as far as I have understood  ;)
shit happens ... that's the Nature of the Beast
« Reply #7 on: April 26, 2022, 03:43:26 AM »
Yeah they were very quick to offer a replacement which was nice, to boot it will be the new HP2560 console not the HP2550
Offline Phil23
    • Phil's Backyard
« Reply #8 on: April 27, 2022, 04:20:57 PM »
Not much more I can think of.
It is definately a DHCP issue I think as the Omada Controller confirms it's MAC & there's no IP.
That should come from a Windoes DHCP as 192.168.XXX.232
All my AP's have current firmware.
Might be a case of rebooting the lot & see;
There's 7 AP's & 3 switches in the link to the closest AP's, but if there were issues there all the other devices would be experiencing issues.
2 GW10/1100's, Airlinks, & a few other wired & Wifi devices, but all getting the Addresses from the same reservation pool.
Omada shows me this history which gives a loose indication of when the issues began.
Offline Phil23
    • Phil's Backyard
« Reply #9 on: May 06, 2022, 02:13:04 AM »
Still haven't Progreesed much on a resolution for this, but managed to roughly identify a bit of my upgrade timeline.
Looks like I downloaded 1.7.8 to my PC on 26/06/2022, would assume I installed it on the same day.
Data appears to have stopped after 5:45am on 17/04/2022.
Potentially after a power interuption.
1.8.0 was downloaded 22/04 & didn't change anything.
Cheers.
Offline Phil23
    • Phil's Backyard
« Reply #10 on: May 06, 2022, 02:37:51 AM »
Two last ditch attempts,
Added a new SSID to my Omada Network, assigned it to a single AP, etc, etc,
No change still fails to get an IP address.
2nd thing I tried was connection it to my 4G Mobile Router.
https://www.telstra.com.au/internet/mobile-broadband/prepaid/telstra-pre-paid-4gx-wifi-plus
Again, the 4G shows the EW connected by I don't think it's getting an IP as the console is still not showing the relevant connected icons.
Offline Phil23
    • Phil's Backyard
« Reply #11 on: May 07, 2022, 07:21:16 PM »
Mine can still scan all the Wifi AP's but just stays in the "Connecting" state on the Wifi Screen.
Think I can rule out an update causing it due to the 5:45am data stop.
Having now tried it on a different AP, I'm pretty sure the Wifi layer connection is happening OK,
it's the next layer of getting an IP address that has fallen apart.
Where do I go from here?
Request replacement & how?
I actually purchase two complete units.
This first one on 15th June 21 & a second one on 25th July 21, so both still in Warranty.
« Last Edit: May 08, 2022, 06:01:37 AM by Phil23 »
Offline Phil23
    • Phil's Backyard
« Reply #12 on: May 17, 2022, 05:54:24 AM »
Emailed Ecowitt about my issue a day or so back, Sunday maybe.
Looks like a replacement is now on it's way.
Would have to say the Customer experience so far is just superb.
No email Ping Pong, just stated the issue in detail & they seem to have dealt with it.
Will now watch to see how the tracking number moves forward.
Offline kheller2
« Reply #13 on: May 17, 2022, 08:30:58 AM »
While you wait you could do a tcpdump on the windows side looking at the DHCP packets to see if you ever get a request from the weather console MAC address for an IP.
Ambient Arrays: WH65B
Ecowitt: HP2551BU, GW1000B(dead), GW1100B(2), GW2000B
Ecowitt Sensors: WH51, WN34BL, WN34(2), WH31, WH41, WH40
Offline Phil23
    • Phil's Backyard
« Reply #14 on: May 18, 2022, 05:12:07 PM »
There was no mention of a 2650 in my discussions with EW. Offered a choice of a replacement console or a GW1100.
Went with the console as who knows if the other Wireless side might fail next.
While you wait you could do a tcpdump on the windows side looking at the DHCP packets...
Was thinking along those lines, but wasn't sure where to start.
Have looked at a few means of checking now & will try if I get a chance.
DHCP Server is a Win2008R2 DC.
Offline Phil23
    • Phil's Backyard
« Reply #15 on: June 01, 2022, 08:44:16 PM »
Decided to have a look at this yesterday afternoon. Not sure yet what it means but the last lines repeat indefinately.
Dump taken from my 2008R2 Server that does my DHCP.
17:07:26.492306 40:f5:20:xx:xx:xx (oui Unknown) > Broadcast Null Supervisory, Receiver not Ready, rcv seq 64, Flags [Poll], length 46
17:07:26.492306 b4:99:ba:xx:xx:xx (oui Unknown) > 40:f5:20:xx:xx:xx (oui Unknown) Null Unnumbered, dm, Flags [Final], length 46
17:07:26.492306 00:11:0a:xx:xx:xx (oui Unknown) > 40:f5:20:xx:xx:xx (oui Unknown) Null Unnumbered, dm, Flags [Final], length 46
17:07:31.161306 40:f5:20:xx:xx:xx (oui Unknown) > Broadcast Null Supervisory, Receiver not Ready, rcv seq 64, Flags [Poll], length 46
17:07:41.293306 40:f5:20:xx:xx:xx (oui Unknown) > Broadcast Null Supervisory, Receiver not Ready, rcv seq 64, Flags [Poll], length 46
40:f5:20:xx:xx:xx Is the Ecowitt
b4:99:ba:xx:xx:xx Is My LaserJet P3015DN
00:11:0a:xx:xx:xx Is My LaserJet 2300DN
Not sure why traffic would be going from the printers to the Console, maybe just Broadcast packets.
https://www.google.com/search?q=Broadcast+Null+Supervisory%2C+Receiver+not+Ready
« Last Edit: June 01, 2022, 08:46:16 PM by Phil23 »
Offline Phil23
    • Phil's Backyard
« Reply #16 on: June 05, 2022, 10:50:09 PM »
New Console arrived today.
I assume the backup that the old one does to the SD card is not of any use?
Didn't notice a restore option.
Assume I need to just enter all required options, but also manually edit the Sensor ID's so they all appearin in the correct order as per the old Console/GW1000/GW1100.
Offline Gyvate
« Reply #17 on: June 06, 2022, 01:53:29 AM »
there is no restore option - hence there is no use of this backup for restore (but maybe for other purposes depending on your use case) - I would just do a full backup and migrate the SD card to the new console
correct
Offline Phil23
    • Phil's Backyard
« Reply #18 on: June 06, 2022, 06:33:27 PM »
All done, but with one notable issue.
Wifi on the new console all connected fine & then matched all previous settings.
On going to Lat & Long, I found them defaulted in the original console.
That is a setting I definitely set as I occasionally looked at Sunrise/Set etc.
Maybe that & Wifi issues point to some sort of NVram failure in a particular area.
