I connected the heating at my second location yesterday to a WS90 Wittboy. I paired this additionally with a WIFI socket so that I could have full control over the under-roof heating and only turn it on when necessary, i.e. during snowstorms and freezing snowy weather when instrument icing is most likely and as I have experienced in the past.
I have noticed a strange anomaly in the data which relates to the behaviour of the lithium batteries. After running the heater, the voltage in the cells, which are only 4 months old, dropped after a few minutes. Previously, according to data from the Ecowitt app, they had between 3.24V and 3.28V. The capacitor at the time was 2.4V. Currently in Poland we have the shortest days of the year, the weather is cloudy, which does not allow supercapacitors to charge. Often the WS90 Wittboy has switched to battery power in the past weeks.
Within minutes the voltage dropped from 3.28V to 2.8V. In the Ecowitt and Wsviev app, a low energy message appeared. Data from the socket control app, indicated 240V and an intermittently switching on heater, which drew up to 12-12.5W, then switched off in a few minutes. Voltage was applied from the mains all the time.
Interestingly in the morning, the voltage dropped to 2.22V, fluctuating slightly. The heater was still running. After sunrise, when scattered radiation appeared, the cell voltage increased slightly to 2.4/2.5V. The capacitor began to charge slowly, despite the heating cable being plugged in. Remotely in the app from the Wifi socket, I had the power disconnected and switched to capacitor and battery power. After a few minutes the low level message from the 2 lithium batteries disappeared, the lithium batteries returned to 3.28V. I am wondering what is causing the current in the cells to fluctuate so much when the heater is switched on and disconnected. Should I be concerned about this or is it just a bug in the applications.
I also have a question as to whether the cable from the heater provides power to the station when there is no battery and the capacitor is discharged. I also present you with a screenshot of the cell behaviour in the WS90 and a link to the station where these unusual fluctuations occurred.
When I have the heating on, it records a slight increase in air temperature, which is measured with an SHT40 in the manufacturer's radiation shield. Turning the heating off remotely, results in less temperature fluctuation. The overestimation of the temperature in my elevated location, however, is no more than 0.2 deg.C/0.5.C higher.
I look forward to hearing from others whether they have encountered strange anomalies in the WS90 Wittboy.
Link to station where anomalies with cell voltage levels are observed:
https://www.ecowitt.net/home/index?id=77800#I use, together with the WS90 Wittboy and the heater power supply, the following WIFI socket, which allows me to remotely control power consumption, heater operation. Link below from Ebay for those potentially interested in remote control of the Ecowitt station.
https://tiny.pl/wflgx
