In case anyone missed the 8-14 day outlook just updated today this is for Feb.14-24. Enjoy Florida...
You aren't kidding.
87 yesterday.
So far this February the mean temp is 65.6. Almost 10 degrees warmer then January.
Flipped the calendar and it changed to summer.
You're getting up there with DanS for warm temperatures in the winter. Am I correct that temps in the 80s are unusual for FL in Feb?
Not at all, 80s are more the Feb norm in FL, often in S TX too. Checked my own Feb 2018 WU data table and the month's high was 84.2Fdeg, with a 59F average. Have seen temps in the 100-107F range in all months, incl winter here too, in the past.
A good place to see it visualized is at NOAA's Climate Prediction Center (CPC) links, the "Regional Climate Maps: USA" here:
https://www.cpc.ncep.noaa.gov/products/analysis_monitoring/regional_monitoring/usa.shtml#monthly .
You can select weekly, monthly, 3mo, yearly climate periods for average temps, precip, extremes, departures, etc., in color-coded graphic form for the whole USA.
Look over the temp and 'departure from normal' maps for any time interval to get an idea. Like for FL, if the temp normal is already approaching 70 or 80, and the departure map shows a 4deg cooler than average for the same period, you can figure that a 'normal ave' would be higher.
If you go to this sublink, the '1 month Archives', you can select any month for various years. Somehow, 2015 is the last year available, maybe processing later ones has been cut off by recent malicious budget cuts to NOAA's budget? (Jan 2019 is available in the 'current' pages at above link)
NOAA's CPC USA Monthly Graphics Archive:
https://www.cpc.ncep.noaa.gov/products/analysis_monitoring/regional_monitoring/1-month-archive.shtmlOf course, all the actual, real, scientific gathered weather data (some from CWOP-MADIS reporting by many here?) in various numerical forms is also available from the CPC, and the rest of NOAA, and can be dug out with varying levels of effort.
But the above links show more usable, readable, graphics (interesting too) derived from all that raw data.
It's all the way down to 63.7F here now, after reaching only 74.2F, dang; but it sure dried out, DP is 39.5F, humidity only 41% .
