Author Topic: Anole's Weather Graphic $winds  (Read 3682 times)
Offline WeatherBeacon
  • Chief
    • http://www.wxbeacon.com
« on: August 04, 2007, 08:47:14 PM »
Hi, folks!
A question about anole's weather graphic. (I use version 5.x.)
I have had the 500x80 banner_big working for several months (see sig below). When I have a wind, the command:
  imagecenteredtext(436, 42, "$winds", 5, 10, $color3, 0);
displays, for example, NW @ 3 mph on banner_big.
I decided to create another graphic using the default 150x150 graphic (I think it's called "default" in the new release?). However, instead of displaying, for example, NW @ 3 mph, it just displays NW @ 3 (no mph). Just inserting mph as text doesn't work, because then when there's no breeze, it displays Calm mph.
I'm stymied. Anyone know what I need to do?
Thanks!
Regards,
Kevin...
« Last Edit: May 07, 2008, 10:53:20 PM by WeatherBeacon »
Mae govannen!
Re: Anole's Weather Graphic $winds
« Reply #1 on: August 05, 2007, 12:25:30 AM »
Kevin,
The code you want is in 'sticker.php' (for V5.x)
 case (($wind > 0) and (empty($_REQUEST["type"]))):
    $winds = "$winddir @ $wind";
  break;
change to
    $winds = "$winddir @ $wind$wind_units";
  break;
and the mph will appear, and disappear when 'Calm'.
Best regards,
Ken
  • Chief
« Reply #2 on: August 05, 2007, 02:47:57 PM »
As always, thanks a lot, Ken! That did it! \:D/
Regards,
Kevin...
Mae govannen!
