Author Topic: Good bookmark for NWS  (Read 6174 times)
Offline anchorageweather
    • http://eetee.us/station/station.php
« on: January 30, 2007, 06:31:24 AM »
If you use the NWS for forecasts, here is something kinda cool you can do with your bookmarks (works for FF, I'm sure it will work for IE too - but I have not tried it):
Create a bookmark with the following code in the "location" field:
javascript:(function(){q=document.getSelection(); if(!q){void(q=prompt('Enter your zip code:',''))};if(q)location.href='http://www.weather.gov/'+escape(q)})()
When you use the bookmark the following box will pop-up:
Now just enter your zip code and it will take you to the NWS forecast for that area.
If you are a WU fan just replace the URL in the script with:
http://www.wunderground.com/cgi-bin/findweather/getForecast?query=
It should save a few keystrokes.  Hope this is helpful  :)
Offline DundeeWeather
    • http://wx.dundeeweather.com/
Re: Good bookmark for NWS
« Reply #1 on: January 30, 2007, 09:12:47 AM »
Very cool!  Thank you sir.
Greg - N2WAI - Dundee, Michigan --- Davis Wireless VP2, VWS 13.00 p20 --- WinXP Pro-SP2
Offline weatherforyou
  • My weather is on WeatherForYou.com. Is yours?
    • http://www.weatherforyou.com
« Reply #2 on: January 30, 2007, 11:56:12 AM »
Joe Torsitano
« Reply #3 on: January 30, 2007, 02:32:13 PM »
Quote from: "weatherforyou"
And for weatherforyou.com it would be...
http://www.weatherforyou.com/cgi-bin/hw3/hw3.cgi?forecast=zandh&pands=
Whoops.... didn't mean to slight your great site, Joe.  Thanks for the heads up.  :oops:
Offline Shawn
« Reply #4 on: June 30, 2007, 05:10:01 AM »
I like weather for you! Great stuff!
Offline CookevilleWeatherGuy
  • Weather Isn't Climate
    • Cookeville Weather Guy
« Reply #5 on: August 04, 2007, 11:19:38 PM »
I like WeatherForYou also! :)
Visit my WEATHER Page:
Davis Vantage Vue
VWS 14.01 p46
WU: KTNCOOKE10
SkyWarn Trained Storm Spotter
CoCoRaHS County Coordinator
Offline FourOhFour
    • skigod.us
« Reply #6 on: August 16, 2007, 10:14:12 PM »
In Firefox, Opera, and OmniWeb (and probably others) you can also set it up so that you can type a keyword and the zip code right into the address bar. I have it set up for "wx <zip>".
To do this in Firefox, just go to your weather site of choice, right click where the zip code goes, and select "Add a keyword for this search"
Then, just name your new bookmark (search keywords in Firefox are stored as bookmarks) and pick a keyword. I suggest something short:
Now try it out... hit command (or control) L (or click in the location bar) and type your keyword, a space, and your zip.
Your Firefox probably already has some search keywords configured; look in Bookmarks -> Quick Searches to see which. (wp for Wikipedia is probably the most useful one in there)
(I gave the directions for Firefox since that's probably more popular than Opera or OmniWeb. For OmniWeb it's "Add Search Shortcut" and for Opera it's "Create Search")
Offline Mark / Ohio
  • Live from Mars!
    • Fairfield County Weather
« Reply #7 on: August 16, 2007, 10:42:33 PM »
Cool!  Thanks!  I just tried it for Weatherforyou (wf) and Weather Underground (wu) using Firefox.   8)
