Author Topic: WS-2000 Calibrating for CWOP  (Read 2533 times)
Offline rjdj2000
« on: April 02, 2025, 07:23:38 PM »
Hello,
I have been trying to calibrate my barometer so I can get rid of the L3 mark on my station on CWOP (ID: GW5159)  So far I have been way confused on how to do this and I have probably messed things up pretty good.
I tried to go by this guide on the CWOP site :https://harriscountyskywatcher.com/2021/03/16/ambient-weather-ws-2000-barometer-calibration/
Thought I had it but I doubt it as it was worse on CWOP after I did it then before.
So, I sent email to support and they sent me to here.  I've looked around and tried to re-calibrate it and still is way off.
So I have went to this site to get my elevation https://www.freemaptools.com/elevation-finder.htm
I get 367m or 1204.1 ft. on that site
Right now my barometer on my control unit is reading: REL - 1021.6 hpa and ABS - 1020.7  The nearest METAR site from me is my local airport, KN03, which is showing 1020.4 mb on the altimeter.  My indoor remote sensor is showing 28.83 inHg.
So using these figures, how to I calculate what to put in for REL and ABS on my console?  I know these values will change by the time someone sees this and responds, but I just need a down and dirty simple way to calculate this and what/how to change.  I know from reading in here that if I change the REL, the ABS will change and vice versa.
Any help is greatly appreciated.
Jeff
Offline R.Sidetrack
Re: WS-2000 Calibrating for CWOP
« Reply #1 on: April 03, 2025, 10:21:17 AM »
I don't have any Ambient devices, but I suggest reviewing this Wiki for more info: https://meshka.eu/Ecowitt/dokuwiki/doku.php#hp2550_hp2560_-_ambient_ws-2000_ws-4000_ws-5000_-_froggit_hp1000pro_se_hp2000
Graham
--- Variety of 'discrete' Ecowitt devices; CumulusMX on Raspberry Pi4 ---
Offline rjdj2000
« Reply #2 on: April 03, 2025, 10:48:54 AM »
Will have to check firmware on it as there is no elevation shown in my unit that I know of.
Offline zeppline
    • Las Vegas Weather Guy
« Reply #3 on: April 03, 2025, 11:06:57 AM »
Your elevation is in calibration, Altitude for rel.
Offline jaltman
    • Stanley Rapids Weather
« Reply #4 on: April 03, 2025, 01:34:57 PM »
My Ambient CWOP i have to adjust the ABS barometer to get in calibration.  He performs the REL from the elevation.
Jim
Offline gszlag
  • "barometers always need correcting"
« Reply #5 on: April 03, 2025, 01:43:47 PM »
Hello,
Jeff
If you do not see an Altitude entry field in your set-up screen you are using the old firmware which used a fixed offset. The fixed offset is the difference in pressure between your barometer's elevation and  the pressure at sea level. This fixed offset/difference in pressure is called the REL offset.
Here's a guide - may be not as simple as you might like but I've included an example which should help:
Calibration – Ambient Weather WS-2000
Some display consoles do not have separate offsets [like the WS-2000] in their firmware. Although not as intuitive, you still can use offsets to properly set up and calibrate your weather station's barometer.
Here's a guide or "how-to" that shows an example of how to properly set up a "non-offset" display console: If you follow this guide, your "non-offset" console will be just as accurate as a console that has separate offset adjustments.
Our objective is to set the elevation of our barometer and to adjust our barometer for best accuracy.
Let's show an example of how these settings would need to be entered. We'll assume you have a brand new weather station, and you are setting it up for the first time. If you have an existing weather station with a "non-offset" display console and have already made some adjustments, skip to Step 3.
Step 1 - review factory default settings:
The default settings:
a) default units are inHg units (inches of mercury)
b) ABS = REL
Note. I will be using a theoretical current pressure reading of 28.53 inHg as an example.
Out-of-the-box, the barometer settings might look something like this:
ABS = 28.53 inHg
REL = 28.53 inHg
We should change to hPa units for better precision for the calibration process. After calibrating, you can switch back to your preferred units:
Step 2: Changing default units from inHg to hPa:
Change the units in the console from inHg to hPa. The console will automatically convert the units to the equivalent hPa values - no manual calculations necessary. For the illustrations (below), all values will now be in hPa (hectopascal) units. Therefore, the default setting of 28.52 inHg will be converted to 1000.0 hPa:
Default settings in hPa:
ABS = 1000.0
REL = 1000.0
Step 3: Setting the elevation
EXAMPLE:  adjust settings for a 300-meter elevation:
Calculate your REL offset by using an online calculator. The calculator will calculate a "pressure difference" number, which is the REL offset number that we need.
https://www.sensorsone.com/icao-standard-atmosphere-altitude-pressure-calculator/?ab=4&v2=300&f2=m&v3=0&f3=m&f4=hPa
[just modify the example inputs to your altitude and preferred units]
Based on a 300-meter elevation, the calculator calculates a pressure difference number of 35.5 (rounded) so grab a pen and paper and add it to whatever is showing as your current ABS value below:
ABS = 1000.0 (current live reading)
REL = 1035.5 (adjust REL manually and change the value until it is exactly 35.5 higher than the ABS value.
Step 4:  Compare REL (relative pressure)  to an airport: (adjusting for accuracy)
We want our REL to be equal to the Altimeter (setting) at the airport, so we compare the values and make note of any discrepancies between the two values. In the example below, the two values don't match:
REL = 1035.5 (our barometer's reading)
Altimeter (setting) = 1036.5 (the airport's reading)
Note the discrepancy in values. Our REL (relative pressure) is too low by 1.0 hPa compared to the airport.
CAUTION: Do not adjust/change the REL value a second time!. The offset must remain at 35.5 (for a 300-meter elevation). If you change the REL value a second time, you will change the REL offset (the difference between REL and ABS) and your elevation setting of 300 meters will be ruined.
From here on, to make further adjustments, we have to switch our attention to the ABS value.
Step 5: Matching the airport (adjusting ABS):
In Step 4 (above) we found out that our REL was too low by 1.0.
To fix that, we increase the ABS value (absolute pressure) by 1.0 which will, at the same time, automatically move the REL up by 1.0.
Your display will look like this for a 300-meter elevation.:
ABS = 1001.0 (you manually changed the ABS value from 1000 to 1001)
REL = 1036.5 (REL automatically increased by 1.0 when you increased ABS by 1.0)
Note: Our REL = 1036.5 now matches the airport's Altimeter setting of 1036.5 which is what we wanted to achieve.
Step 6: Final tuning:
Because we calibrated our barometer when the airport was reading 1036.5, our barometer will start to “drift” in accuracy when the pressure increases or decreases from 1036.5. The farther the pressure is from 1036.5 – the higher the error.
The REL pressure will, of course, change over time and 1036.5 is probably, well above the average pressure for your location. Therefore, for best accuracy, the next time the airport Altimeter setting reads closer to normal (around 1013.25), you should re-adjust your ABS value once again so that your REL value on the display console matches 1013.25 at the airport.
By fine-tuning, you are shifting the calibration curve so that you are obtaining the maximum accuracy around the average pressure for your location, rather than setting the maximum accuracy at a very high (or low) pressure.
Congratulations! You are now calibrated.
The barometer wiki has a new home!
 www.barometer-wiki.ca/barometer
Personal weather stations (pws):
Ambient Weather + Ecowitt
Station elevation: 191 m
METAR: CYZE Elevation 189.9 m
Offline rjdj2000
« Reply #6 on: April 03, 2025, 02:47:48 PM »
Hello,
Jeff
gszlag,
Thanks for the information.  I will check my station tonight to see if there is an update available to the firmware.  If there is, I will update it and see if there is a setting for elevation.  If not, I will go through your instructions and see how I come out.  If there is the elevation setting in it, what should I do for setting the pressure?  Go with what the nearest METAR says or is there a way to take that value and calculate what it should read?
Jeff
Offline jaltman
« Reply #7 on: April 03, 2025, 02:54:26 PM »
The latest WS-2000 does not have the elevation setting.  Its about 2 years old.  If you are going through the Ambient CWOP, which is what i do, i am telling you that its looking at the ABS value to determine validity.  https://ambientweather.com/faqs/question/view/id/1415/
Jim
Offline gszlag
« Reply #8 on: April 03, 2025, 03:52:54 PM »
Do not update your firmware yet.
The procedure I gave you allows you to display Altimeter as the REL on your display console and at the same time, ensures your ABS is accurate.
As you are currently uploading to CWOP (ambientCWOP.com?), keep in mind that CWOP compares your readings with neighbouring stations that may have calibrated and uncalibrated barometers that are dragging down the averages.
Please read Beaudog's dissertation on QA here:
https://www.wxforum.net/index.php?topic=21987.0
Once you are matching the REL on your display with a close-by airport(s) and are calibrated using the Altimeter setting method (above) then you might consider upgrading your Ambient station with the Ecowitt firmware upgrade and take a look at data logging software like WeeWX or Cumulus MX. Both of these softwares can upload to CWOP.
A question to ask yourself - if you upgrade the firmware, your REL will be displaying only SLP  from now on.  Will you be happy with that?
Offline rjdj2000
« Reply #9 on: April 03, 2025, 04:11:47 PM »
Well there is no firmware update for this one, just a WiFi update, which I've done.
The link above, shows same firmware that is installed.  Yes this is going to the Ambient CWOP.
Right now METAR KN03 shows 1010.9 and mine is showing ABS 1011.6 and REL 1012.5.  So I might be closer than I think.  I am like 9 or so miles away from this METAR site also.
For now I think I'll let it settle in a bit and then check it this weekend.  Then run through the procedure above to try to get it into line.  A day or so ago I was closer but it said the L3 was still off but if nobody around me has calibrated it, it probably would be off.  After a quick glance at the other thread, I guess I shouldn't be too concerned as long as i know it is correct. LOL
gszlag, I just went to your link above to find the difference, for 367 meters it shows me 43.3 rounded.
Using what you said, I should change the REL in my station as such: (using my current values as example)
ABS shows: 1011.6
REL shows: 1012.5
So I take the ABS of 1011.6 and add the 43.5 = 1054.9 and change the REL value.
Then once that is done, I take the METAR value and the ABS value get the difference of those and either +/- the ABS value.
Just making sure I understand what you said and that I'm doing it right.
Jeff
« Last Edit: April 03, 2025, 04:25:09 PM by rjdj2000 »
Offline alanb
« Reply #10 on: April 03, 2025, 06:17:41 PM »
Ambient always lags way behind on publishing the latest software for the WS-2000 console, but since it is a clone of the Ecowitt HP2550 you can get the latest firmware from the Ecowitt site or from Gyvate's wiki. The wiki is the easiest way to get it ... the link for the wiki is given in the post by R.Sidetrack earlier in this thread, or this link
 https://meshka.eu/Ecowitt/dokuwiki/doku.php#console_firmware_device_wifi_-_latest_versions
will take you directly to the firmware section of the wiki. The latest firmware as of this post is version 2.0.4 and will change the calibration screen on your WS-2000 to include the entry for the barometer Altitude on the calibration screen.
Note: I have a Ambient WS-2000 station and have updated to version 2.0.4. The firmware installs without a problem on the WS-2000 and works just fine for me. However, as gszlag cautioned, it does change the REL barometer algorithm from altimeter to SLP.
« Last Edit: April 03, 2025, 06:33:27 PM by alanb »
Alan - Ambient WS-2000, Ecowitt GW3000, WH31E x5, WH31L, Ecowitt WN32(WH32E)
          Airthings Corentium Home Radon Detector 223
My station dashboards - WU  AWN  ECOWITT
Offline gszlag
« Reply #11 on: April 03, 2025, 07:57:25 PM »
KN03 032235Z AUTO 25005KT 10SM BKN050 OVC065 17/07 A2994 RMK AO2|
|Conditions at:|2235 UTC 03 Thu Apr 2025|
|Temperature:|17°C (63°F)|
|Dewpoint:|7°C (45°F) (RH = 52%)|
|Pressure (altimeter):|29.94 inHg (1014 hPa)|
|Winds:|from the WSW (250°) at 5 kt (2.6 m/s, 5.8 mph)|
|Visibility:|10+ mi (16+ km)|
|Clouds:|broken clouds at 5,000 ft, overcast at 6,500 ft|
|Ceiling:|5,000 ft|
There is something wrong.
Since you live above sea level, your local pressure (ABS) of 1011.6 at your elevation/altitude can't possibly be higher than the pressure at sea level (1010.9).
In the METAR KN03 report above, Altimeter setting is A2994. I have marked it in bold.
Is your airfield Cortland County/Chase Field - N03/CTX?
If so, A2994 = Altimeter setting = 29.94 inHg = 1013.88 mb = 1013.9 mb or 1013.9 hPa (rounded).
I am not sure where you got 1010.9 mb as the Altimeter setting for METAR KN03
If I got the wrong airfield let me know but we will use the METAR KN03 report "as is" for an example.
A2994 converts to 1013.88 mb = 1013.9 mb (rounded)
Our goal is to get your WS-2000 console to have a REL = 1013.9.
Your current REL on the display = 1012.5.
It might be easier to match the REL first and then adjust the ABS:
1. set REL = 1013.9
2. subtract the REL offset (pressure difference) of 43.3
Therefore 1013.9 - 43.3 = 970.6 (ABS)
Basically your console adds 43.3 to whatever the ABS is currently displaying.
As mentioned in the tutorial, the tricky part is maintaining the spread of 43.3 between ABS and REL. Therefore when you set REL = 1013.9 do not touch it again. Go on to adjust ABS to 970,6 and then to make minor adjustments to REL, just change the ABS value. You will note that when you change ABS, the REL will move by exactly the same amount.
Double check that the spread of 43.3 stays intact after all the button pushing is done!
Let us know how it goes..
Offline rjdj2000
« Reply #12 on: April 04, 2025, 06:12:30 AM »
Yes that is my local airport and I am not sure where that number came from as I have so many wrote down trying to figure this all out.  I appreciate the help in trying to understand this.
So as of me writing this, current METAR is:
METAR for:   KN03 (Cortland/Cortland Cnty, NY, US)
Text:   KN03 040935Z AUTO 30003KT 10SM SCT028 OVC080 05/00 A3016 RMK AO2
Conditions at:   0935 UTC 04 Fri Apr 2025
Temperature:   5°C (41°F)
Dewpoint:   0°C (32°F) (RH = 70%)
Pressure (altimeter):   30.16 inHg (1021.4 hPa)
Winds:   from the WNW (300°) at 3 kt (1.5 m/s, 3.5 mph)
Visibility:   10+ mi (16+ km)
Clouds:   scattered clouds at 2,800 ft, overcast at 8,000 ft
Ceiling:   8,000 ft
So basically what you said above is to set my REL to the A3016 = 1021.34 mb
Then deduct the 43.3 from that and set my ABS to 978.0.
When I went into my console and set the REL to the above, it stayed until I put in the ABS.  I exited out and the REL was also around 978, so I went back in and set REL to the 1021.3 and exited out.  Went back in to the calibration page and everything stayed to what I set it for.  So now to see how it reads through the day and I will check it against the METAR site and go from there.  Hopefully I won't have to mess with it again for awhile.
Jeff
Offline rjdj2000
« Reply #13 on: April 04, 2025, 06:39:40 AM »
Well to report back after adjusting it.... Ambient CWOP is now showing that it passes the L3 check.
Thanks again for the help and will keep tabs on it for the next couple days and if I need to adjust it, I'll adjust the ABS value as directed and make sure it adjusts the REL accordingly.
Jeff
Offline gszlag
« Reply #14 on: April 04, 2025, 06:49:37 AM »
Congrats - I believe you've got it!
Your console should now be tracking Altimeter at your airport.
Normally you have to be absolutely certain that you and your airport are under the same pressure system but in your case, you are very close to an airport  so chances are you will be almost always in the sme pressure system.
Although you will be tracking Altimeter with reasonable accuracy, a fixed offset estimate will be slightly off at times.
Additionally, Altimeter is not used for meteoological purposes so I would encourage you to update  to the SLP algorithm at some point. As alanb mentioned, you can use the Ecowitt firmware update to upgrade your Ambient WS2000. I have upgraded my WS-2000 with absolutely no issues.
You may find the barometer wiki to be a useful resource for all things barometric:
Offline jaltman
« Reply #15 on: April 04, 2025, 06:52:56 AM »
If you install the Ecowitt firmware to the WS-2000 can you stlll upload to ambient.net?
Jim
Offline gszlag
« Reply #16 on: April 04, 2025, 07:04:07 AM »
Jim
AWN? Yes, certainly.
Offline rjdj2000
« Reply #17 on: April 04, 2025, 07:04:24 AM »
Thanks.  It was just weird when I put the values in, REL first, that when I put ABS in, it changed the REL but that would probably be right to do so.  I am just glad that the values stuck after I changed the REL again.  I will look at the upgrade as I like being able to see what is going on at home while I'm away.  I have used Cumulus before on an older LaCross unit but the rain gauge and wind speed gave up the ghost awhile back.  To replace those two sensors was about as much as getting a new unit.  So I opted for the new unit and it sits atop a post in my backyard without anything really around it.  So if I have to go back to that, to send into CWOP and to have a place to lookup my home weather while away, I probably can figure it out.
Jeff
Offline jaltman
« Reply #18 on: April 04, 2025, 07:10:22 AM »
I assumed that to be the case since the wifi is a different file, but i do things out of AWN, i.e. CWOP and PWSWeather i'd have to change to another upload.  PWS gives me free access to Xweather forecasts and custom local radar maps i use in my website(s).
Thanks.
Offline rjdj2000
« Reply #19 on: April 04, 2025, 07:26:55 AM »
After just skimming the WiKi for the firmware upgrade, it is probably going to be a bit before attempting that one. LOL  I will have to read through it a few times so I can figure it all out and then go from there.  As my About page looks different then what is shown.
Offline jaltman
« Reply #20 on: April 04, 2025, 03:33:17 PM »
Just wanted to say thanks.  The conversion to the Ecowitt firmware went fine, lost no data, had only to set the station altitude to be back to normal running. Now all the numbers match between the Ecowitt based system and the Ambient. Nice.
Jim
Offline rjdj2000
« Reply #21 on: April 04, 2025, 04:51:00 PM »
Jim
Jim,
So basically just d/l the firmware, put on sd card, insert in station and power it up?  Will have to look again and see for sure and may have a go at it this weekend. LOL
Jeff
Offline alanb
« Reply #22 on: April 04, 2025, 04:58:32 PM »
Have to unzip the file after downloading, but otherwise, yes, it is that simple.
Offline rjdj2000
« Reply #23 on: April 04, 2025, 05:08:07 PM »
Ok... Guess I'll try it....  Now using the info in the about page shown above, I should get this file: hp25x0_user_v2.0.4.zip (I've already downloaded it and unzipped it)  Just wanted to confirm that was the file needed for my console.
Jeff
Offline jaltman
« Reply #24 on: April 04, 2025, 06:04:01 PM »
Yup, that's the one that i used.
Jim
